fuel problems
Old Jan 21, 2011 | 04:09 AM
dfbdavid38's Avatar
Icon3 fuel problems
ok poeple heres a good question for all of you my car runs good when the fuel tank is full when it get down past a half of a tank it runs like pure crap ive done put a fuel pump on it and i have no trash in the tamk either any one got a good answer for this?
Old Jan 21, 2011 | 04:28 AM
GhostAccord's Avatar
Default Re: fuel problems
Do you have a fuel pressure gauge that you can put on the rail to monitor if there is a drop in fuel pressure as the tank gets lower?
Could be a power/voltage drop issue going to the fuel pump. Maybe there is only enough juice for the pump to sip at your tank. Then as it gets lower the pump doesn't have enough juice to really suck up the fuel.......?????
Testing the voltage at the pump and the pressure at the rail would be my suggestion.
Old Jan 21, 2011 | 04:40 AM
dfbdavid38's Avatar
what would the volts be at the pump and how do i check this
Old Jan 21, 2011 | 05:27 AM
The volts at the pump should be battery voltage. You will need a multi/voltmeter and the following procedure;
This is for a 94-98 Accord,
the procedure will be the same for testing on other models, However the locations of the connections may differ.
canospeed200
May 18, 2011 06:05 AM
95ITRJDM
Apr 10, 2011 06:09 AM
SlowSlammedSedan
Jan 10, 2009 06:50 PM
civicjoe
Mar 5, 2008 12:40 PM
HmgLauj69
Dec 23, 2005 05:48 PM
