Alignment on a lowered car???
Old Feb 4, 2002 | 10:04 AM
RATEDR's Avatar
Default Alignment on a lowered car???
I need to have my car aligned and do to my works alignment machine being up-rooted for renovation purposes, I need to get it done elsewhere. Since im lowered (Mugen lowdown) do I need to tell them to align it to stock specs or should my alignment be different do to it being lowered? Or will the fact being its lowered not allow it to hit stock specs anyways so they will just get it as close as possible?
TIA
Old Feb 4, 2002 | 11:26 AM
KF_S2000's Avatar
Default Re: Alignment on a lowered car??? (RATEDR)
Since the Mugen Lowdown suspension setup is a relatively mild drop (.75" I believe) you'll probably be IN spec for all alignment settings except camber. You'll have a little more negative, but I wouldn't worry about it. Our suspensions are not adjustable for camber in stock form, so some type of modification must be made if camber is to be adjusted. However, I feel that the additional negative camber is not going to be to the degree that it's going to cause negative side effects.
TonyRomo
Jul 20, 2009 01:24 PM
SportEL
Suspension & Brakes
29
Dec 20, 2007 06:46 PM
$amGD3
Suspension & Brakes
11
Sep 5, 2005 05:16 PM
Ludeboi
Apr 25, 2003 11:26 PM
imported204
Sep 1, 2002 07:19 AM
