Will a car run without a battery?
Old May 10, 2005 | 03:13 PM
CRXDrew's Avatar
Default Will a car run without a battery?
Just wondering. Can a car after its started run without a battery. I had a bad battery/alternator and since then have replaced both. Just wondering if the battery was bad could the alternator sustain the car during highway driving?
Old May 10, 2005 | 04:20 PM
B16Civic93's Avatar
Default Re: Will a car run without a battery? (CRXDrew)
well if the alternator works and the car is running than yes it will keep running but only if the battery is able to hold a small charge, however if the battery will not hold a charge than it will not start up again. i would suggest just getting a new battery. if you had a magnito than it would stay running
Old May 10, 2005 | 04:40 PM
eg6T's Avatar
Default Re: Will a car run without a battery? (B16Civic93)
if the battery dies,yea it will stay running but if it gets disconnected the car will shut off
Old May 10, 2005 | 04:59 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Will a car run without a battery? (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">if the battery dies,yea it will stay running but if it gets disconnected the car will shut off</TD></TR></TABLE>
Off my old school Prelude I removed the terminals completely off the battery. Still ran.
Old May 10, 2005 | 06:31 PM
eg6T's Avatar
Default Re: Will a car run without a battery? (INVALID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID &raquo;</TD></TR><TR><TD CLASS="quote">
Off my old school Prelude I removed the terminals completely off the battery. Still ran. </TD></TR></TABLE>
i was driving and my terminal came off and my car totally died and i had to pull over and reconnect it...
Old May 10, 2005 | 06:51 PM
Brian Hinson's Avatar
My battery cable came loose one day while I was driving, and I didnt realize it until I got back in my car to leave, and it wouldnt crank
Old May 10, 2005 | 09:16 PM
Tmack's Avatar
if you pull the battery while the car is running it will run depending on the style of circuit the car has. The bad side of this is when you reconnect the battry the surge of power will blow the regulator.
Old May 11, 2005 | 01:24 AM
CRXDrew's Avatar
Yea... I had this happen: I was running an AZ alternator and a small hawker battery for the longest. Car would never start up if it sat for a day or two and the battery would lose charge.
replaced the battery... went ok for a while... problems reappeared
replaced the alt... then new battery wouldn't hold charge
(figured messed up alternator killed the first battery and now the second one aswell)
replaced the alternator and warranteed the battery...
Now everything seems ok, stupid Autozone alternators. Oh well.
tomatolord
Jun 14, 2015 02:13 PM
integracura
Acura TSX
Apr 5, 2009 06:42 PM
rewerbcrx
May 12, 2007 05:45 AM
MidwestSi
14
Jun 20, 2005 02:54 PM
mjrage
18
Jun 25, 2004 06:28 PM
