Problems with overheating 92 eg Hb DX
Old May 10, 2005 | 03:01 PM
BookEG's Avatar
Default Problems with overheating 92 eg Hb DX
I changed the theromsant today because the last two weeks it started to overheat, so i take it for a test drive and when i come to a red light it starts to overheat so i turn the heat on and it finally goes down when i get home i look under the car and there's no leaks, pop the hood to see if anything else is leaking but nothing. What else could it be i wouldn't think it would be the water pump becuase its not leaking or it wouldn't be a sensor because there's no check engine light
Old May 10, 2005 | 03:08 PM
alleyezonme's Avatar
Default Re: Problems with overheating 92 eg Hb DX (BookEG)
sounds like it could be your fan not switching on, or even a head gasket!
Old May 10, 2005 | 03:12 PM
BookEG's Avatar
Default Re: Problems with overheating 92 eg Hb DX (alleyezonme)
if it was the headgasket wouldn't overheat while driving
Old May 10, 2005 | 04:10 PM
dc2vu's Avatar
maybe u have no coolant?
Old May 10, 2005 | 04:14 PM
JDMlyfestyle's Avatar
did you bleed the coolant?
Old May 10, 2005 | 04:17 PM
BookEG's Avatar
Default Re: (JDMlyfestyle)
how would i bleed the coolant and yes the coolant is full
Old May 10, 2005 | 04:37 PM
Mooney's Avatar
make sure there are no binds in the coolant lines. Sometimes if the flow of the coolant can be restricted causeing it to overheat. Also take off the hoses and make sure there is no corrotion or what not stuck in the lines.
Old May 10, 2005 | 04:53 PM
how to bleed your coolant.
let the car become cool.
take off the radiator cap
start the car.
let the car run for 10-20 mins without the cap on and watch all the bubbles.
once the car has reached operating temperature put more coolant in and let it run for another 5 mins. add coolant if bubles still appear
when there are no more bubbles put the cap back on and turn the car off.
Old May 10, 2005 | 05:01 PM
litterbox's Avatar
I am a (Trial User) Army
Also, put it on high heat when you bleed.
Old May 10, 2005 | 05:06 PM
TurboTagTeam's Avatar
Default Re: (litterbox)
Definatly check the coolant first
If thats not it change the gasket
Old May 10, 2005 | 05:37 PM
civicboisi's Avatar
Default Re: (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam &raquo;</TD></TR><TR><TD CLASS="quote">Definatly check the coolant first
If thats not it change the gasket</TD></TR></TABLE>
Sounds like what my B7's doing
Old May 10, 2005 | 05:41 PM
BookEG's Avatar
i did that i let it run until it warmed up and added coolant, i was thinking it might be one of the hoses that has a small crack in them but there all fine, if it is the headgasket i'm not spending any money on the pos motor. I'm saving for a h22
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (civicboisi)
if your head gasket is shot, you'll be getting white smoke out of your exhaust.
is there any smoke?
and is your fan turnong on, by the way?
anyway, i agree just bleed your coolant system- i bet that's all it is. and hopefully too, because it saves you the trouble of doing a new headgasket.
Old May 10, 2005 | 05:48 PM
BookEG's Avatar
Default Re: (Screwtape:)
yea the fan turns on,its been blowing white smoke since i've owned the car it blows it when i take off but its been doing that for 4 months now
Old May 10, 2005 | 05:51 PM
civicboisi's Avatar
Default Re: (BookEG)
does the smoke smell sweet? Chances are it's the headgasket...you're describing the same thing my motor is doing (d15b7) and it ended up being the head gasket after i changed my thermo and bleed my coolant.
good luck with yours!
btw...what does ur oil look like? Remember head gaskets can blow internally and externally so even though your oil looks okay, you still could have a leak internally.
Old May 10, 2005 | 05:53 PM
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BookEG &raquo;</TD></TR><TR><TD CLASS="quote">its been blowing white smoke since i've owned the car it blows it when i take off but its been doing that for 4 months now </TD></TR></TABLE>
yeah, well it was probably a minor head gasket leak over the past four months, and was enough to puff out white smoke but ..and i'm not trying to sound like a jerk.. you've obviously ignored the white smoke for 4 months and now you've got white smoke AND driveability problems and harmful engine operation.
suggest replacing head gasket.
Old May 10, 2005 | 06:06 PM
BookEG's Avatar
no joke it burns about quart 1/2 oil a week
Old May 10, 2005 | 06:08 PM
civicboisi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BookEG &raquo;</TD></TR><TR><TD CLASS="quote">i did that i let it run until it warmed up and added coolant, i was thinking it might be one of the hoses that has a small crack in them but there all fine, if it is the headgasket i'm not spending any money on the pos motor. I'm saving for a h22 </TD></TR></TABLE>
and thats why i have a y7 sitting in my driveway... But im still running the b7 to the ground...shes stubborn! Just watch ur coolant level...if it goes down after a few days, it's your headgasket.
grndslm
Sep 4, 2013 10:05 PM
lfunk11
Honda Civic (2001 - 2005)
Jan 16, 2012 12:34 AM
LilBlaccHatch20
Mar 7, 2007 01:48 PM
som3on3_10
May 18, 2006 06:56 AM
jvonb
Dec 2, 2005 03:15 PM
