Suspension & Brakes Theory, alignment, spring rates....
brake swap problem!
Old May 10, 2005 | 02:53 PM
0ptimus prime's Avatar
Default brake swap problem!
I swapped on integra knuckles onto my 94 EH2. As i understand it, they're supposed to be a direct bolt on with no problems. In my case, there's problems.
- My tires are facing each other to the point to where my alignment shop declined to align it. They said it was impossible to align it with that much of a toe problem.
- It seems as though where the tie rod connects to the knuckle (on these teg hubs) it positions the knuckle itself too far out....thus making my tires look like this // \\ (from a birds eye view, not from behind it.)
- I'm wondering if maybe these are DA integra knuckles, would they be any different from 94-00 knuckles? If so, i'm thinking i have DA knuckles on right now and that's why the tie rod doesn't position the hub where it's supposed to.
I've searched, i know somebody has to have come across this problem! So if these are DA knuckles, DC knuckles should fix my problem right? TIA!
Old May 10, 2005 | 03:28 PM
Default Re: brake swap problem! (0ptimus Prime)
Here's some pics.
Old May 10, 2005 | 05:14 PM
philosofy1's Avatar
knuckles from a dc will fit, not sure from a da, do you have photos of the knuckles installed.
Old May 10, 2005 | 05:32 PM
Default Re: brake swap problem! (philosofy1)
not of the knuckles off of the car, just what you see.
Old May 10, 2005 | 05:50 PM
slammed_93_hatch's Avatar
id say you DO NOT HAVE the front knucels off of a 94-01 integra
Old May 10, 2005 | 07:26 PM
hayabusa160's Avatar
intresting. when i did my 5 lug the alignment in front was almost not affected. the toe was off alittle bit but that was it.
Old May 29, 2005 | 08:13 PM
813STi05's Avatar
Default Re: brake swap problem! (hayabusa160)
Thoes are deff 90-93 DA Knuckles. I just did them on my 93 sol and i had to get skunk 2 upper control arms to fix it.
nustad89
May 4, 2013 11:40 AM
sol_93
Dec 18, 2006 08:11 PM
yOnKiNaToR
Sep 6, 2005 01:35 PM
0ptimus prime
May 10, 2005 04:28 PM
JSPEC98
Nov 8, 2003 11:55 AM
