Speedo jumping around, elec problem??
Old May 10, 2005 | 02:17 PM
JordanCivic's Avatar
Default Speedo jumping around, elec problem??
When i get high in the revs and let off the speedo does some funky dance for a second before returning to normal!! Bounces upto like 100mph ( 2nd ) and then returns to normal.
Any ideas ??? VSS ?? Could this possible cause some drivability issues??
Thanks
Old May 10, 2005 | 04:14 PM
DAguyLS's Avatar
VSS, try just pulling it out and plugging back in. If that doesn't work then i'd go get a new one. Or used one.
Won't cause drivablility issues, just that when your speedo goes to 100mph that also reads on your odometer. So your miles will tick as if you were going 100mph.
Old May 10, 2005 | 04:41 PM
eg6T's Avatar
Default Re: (DAguyLS)
i had to get a new cluster
Old May 11, 2005 | 02:18 PM
Default Re: (eg6T)
Can someone help me locate the VSS, i guess its on the gearbox?? It seems to be getting worse, i hit the limiter today and the speedo dropped to 0 and i lost vtec, turned the ignition off and back on and it came back again. !!
Any suggs??
Old May 11, 2005 | 02:29 PM
I got a vafc2 too, theres no connection to the speedo on there is there?? maybe a bad connection?
Im pretty sure its not connected to the speedo though, someone confirm this please.
Old May 12, 2005 | 05:00 AM
PrettyLude's Avatar
the vss is on the tranny itself, look where your throttle body is, and look straight down, check the connection to the vss, to ensure no moisture is in it
Old May 17, 2005 | 06:34 AM
Ill check that out, any other suggs??
Old May 22, 2005 | 07:45 AM
my brake light has started to come on randomly too
Old May 22, 2005 | 08:45 AM
b18blackek's Avatar
its ur speed sensor on the tranny
Old May 23, 2005 | 03:12 PM
Evil-EK's Avatar
Default Re: (B18BlackEK)
Your brake light will not have anything to do with your vss but if you have a loose ground on the tranny or valve cover these problems can also occur. I would probably just lean towards the vss being bad though.
406EVO
May 18, 2016 11:26 AM
213374U
May 18, 2009 02:08 AM
jxhxb
Dec 29, 2007 08:58 PM
esoterEK..
Sep 30, 2006 02:48 PM
JiVe
19
Jul 22, 2003 01:12 PM
