Distributor wont plug in..?
Old May 10, 2005 | 01:32 PM
mooook's Avatar
Default Distributor wont plug in..?
i have a OBD2 GSR motor in my 2000 Civic EX. Im using the stock EX wiring harness and the GSR distributor does not plug in. Im curious on what dizzy i need and is this common..?
i have never heard of anything like this.
Old May 10, 2005 | 01:51 PM
mooook's Avatar
Default Re: Distributor wont plug in..? (mooook)
anyone..?
Old May 10, 2005 | 03:08 PM
EE_Chris's Avatar
The 96-98 Civics used a 9-pin distributor, while the 99-00 Civics used a 8-pin (lacked the Blu tach wire). Does your harness have a 9-pin connector?
Old May 10, 2005 | 03:55 PM
99exd16y8's Avatar
Default Re: Distributor wont plug in..? (EE_Chris)
bump for more info
Old May 10, 2005 | 04:32 PM
kleanlscivic's Avatar
yea it might be different b/c i think that the gsr is 0bd2a and the 00 civic is obd2b? might be that......bump for help for him
Old May 10, 2005 | 04:37 PM
menkio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">The 96-98 Civics used a 9-pin distributor, while the 99-00 Civics used a 8-pin (lacked the Blu tach wire). Does your harness have a 9-pin connector?</TD></TR></TABLE>
does your connect have 9 pins ?
Old May 10, 2005 | 05:10 PM
Lmgrcivic's Avatar
Default Re: Distributor wont plug in..? (menkio)
if you dont want to switch the dizzy just get the right plug and solder the new one on and you will be good to go wont hurt anything
Old May 10, 2005 | 10:28 PM
mooook's Avatar
Default Re: Distributor wont plug in..? (Lmgrcivic)
it fired up tonite. We had to resolder some ****. And yes whoever said the tach wire was missing is right. The tach works though. Now if i didnt have a bunk p28 i'd be good. But im on the god damn stock ex ecu. Im not driving it, its still sittin i need a new p28 now.
SpoonfedCivic
Feb 10, 2011 07:48 PM
Vtec Civic 93
10
Aug 13, 2010 12:12 AM
length
Dec 12, 2003 07:57 AM
Nameless RB26
Sep 9, 2003 02:14 PM
