LS compression of 90psi with new cp's ?
Old May 10, 2005 | 01:32 PM
ogabudiah's Avatar
Default LS compression of 90psi with new cp's ?
I need to know what compression numbers i should settle for, on an ls with 9-1 CR cp's.
I was expecting a lot higher but i have tested it 3 times and i am only getting around 90.
This is an ls motor with 1500 miles on it.
Old May 10, 2005 | 01:42 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: LS compression of 90psi with new cp's ? (ogabudiah)
Did you do the compression test with the throttlebody all the way open? if not, those #s are horrible
Old May 10, 2005 | 01:43 PM
ogabudiah's Avatar
Default Re: LS compression of 90psi with new cp's ? (PURPLETERROR)
no i didnt ahh how do i am dumb geez
how different are my results going to be
Old May 10, 2005 | 01:52 PM
Finger Lickin' good's Avatar
well, is it easier to breath through a 1/2inch tube, or a 3inch tube. you make the call.
Old May 10, 2005 | 05:29 PM
ogabudiah's Avatar
Default Re: LS compression of 90psi with new cp's ? (D-CeReaL#4)
I did it right and i got 160 all the way across, is that good for 1500 miles?
Old May 10, 2005 | 09:56 PM
ORcivicsi's Avatar
160 psi sounds good for 9-1. I got 210 psi across the board on my stock b16(10.6-1). The mileage doesnt matter, if they are all the same, then your good. Sounds like you got a healthy motor.
Old May 11, 2005 | 03:16 AM
eMpAtHy's Avatar
Default Re: LS compression of 90psi with new cp's ? (ORcivicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ORcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">160 psi sounds good for 9-1. I got 210 psi across the board on my stock b16(10.6-1). The mileage doesnt matter, if they are all the same, then your good. Sounds like you got a healthy motor. </TD></TR></TABLE>
wthell, i am supposed to be at 9:1, but my compression numbers were like 250ish
Old May 11, 2005 | 04:40 AM
ogabudiah's Avatar
Default Re: LS compression of 90psi with new cp's ? (eMpAtHy)
this motor has 1500 miles on the new cp's and 12k since the last true hone so it these rings have to have more time to break in.
anyways 160 is good enough to boost on.
thanks to all
Old May 11, 2005 | 08:47 AM
mmuller's Avatar
Mad Scientist
if your rings did not seat after 1500 miles, then you have a problems....rings do their 90% of seating in the first miles....
remember that compression #'s are going to be dependent on:
compressor tester that you use.
temp.
alt.
So don't worry about other peoples #'s consistency is the key
KDawg08
Mar 7, 2012 10:38 PM
reallycooleg
Mar 8, 2006 09:06 PM
2ndgentegracer
Mar 7, 2006 04:29 PM
vaporboy12
May 19, 2004 10:00 PM
beaterman
Aug 29, 2003 12:07 AM
