How to lean out VAFC
Old May 10, 2005 | 12:58 PM
MisterB's Avatar
Default How to lean out VAFC
How do you adjust a vafc 1 to make the car run leaner?
right now the air fuel gauge is barried in the rich and i need to lean it out for smog test
TIA lost my manual.
Old May 10, 2005 | 05:24 PM
lsvtecracer's Avatar
Default Re: How to lean out VAFC (MisterB)
It all depend on what your setup is. You usually set the point where you would like to pull or add fuel. Then start taking gas out by subtractring the values or increasing by giving it more.
Old May 11, 2005 | 10:05 AM
MisterB's Avatar
Default Re: How to lean out VAFC (lsvtecracer)
my set up is a b16a with ctr internals vafc i/h/e and mugen program ecu and it run so rich even at idle the gauge is all the way in the green rich side
Old May 12, 2005 | 05:05 AM
PrettyLude's Avatar
its the program itself man, it is designed to run really rich
Old May 12, 2005 | 05:51 AM
Padawan's Avatar
Darth ModerVader
And unless the A/F gauge you're referring to is fed by a wide-band O2 sensor, I definitely would <u>not</u> suggest using it as a tuning tool.
4LugR
Nov 17, 2006 06:14 PM
gigantor
Nov 11, 2003 07:59 PM
M-EJ1
Mar 6, 2003 09:59 PM
-Whitey-
Sep 15, 2002 05:26 PM
nfn15037
Sep 25, 2001 12:52 PM
