need help ASAP, anyone out there???
Old May 10, 2005 | 08:07 AM
DTMvelocity's Avatar
Default need help ASAP, anyone out there???
my friends SOHC eg is acting up. it cranks over without problem, but it wont start. my brother was fooling arounf and managed to disconnect the fuel return line, and gas is spraying all over everytime its cranked. also the distributor was somewhat loose, but i believe i took car of that. the car wants to start, but it wont. any suggestion, advice will be appreciated. need help ASAP
Old May 10, 2005 | 08:33 AM
GeeSssAre's Avatar
Default Re: need help ASAP, anyone out there??? (DTMvelocity)
im pretty sure you need 3 things to start a motor. fuel, compression, and spark. it sounds like you have fuel. make sure all fuel lines are connected and check for spark. the dizzy was loose? check the timing. timing is everything. make sure you have the right firing order, and check spark plugs. just my 0.02 good luck!
Old May 10, 2005 | 01:50 PM
Finger Lickin' good's Avatar
Default Re: need help ASAP, anyone out there??? (GeeSssAre)
^ha, you name 3 things but say that timing is everything...wouldnt that make it 4 things.
anywho, check the fuel. the return line is pretty important..
Old May 10, 2005 | 02:22 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeSssAre &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure you need 3 things to start a motor. </TD></TR></TABLE>
4 things: Induction, compression, fuel and spark.
Old May 10, 2005 | 02:26 PM
punkracer's Avatar
not to metion ..... a good ground. been there done that
Ede
May 7, 2017 04:27 PM
2001CRV
Honda CR-V & Element
29
Jan 7, 2013 01:28 PM
NOTDISFA5
12
Apr 28, 2010 11:16 PM
turbocivic0618
Nov 24, 2005 08:20 AM
95civickid
11
Apr 5, 2005 05:52 PM
