who's not running a flexpipe on your FI exhaust.?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">no flex, just 2.5" steel downpipe</TD></TR></TABLE>
same
same
Unless you have really stiff motor mounts, you should run a flex section. It puts alot on stress on the turbo/manifold if you don't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 »</TD></TR><TR><TD CLASS="quote">Unless you have really stiff motor mounts, you should run a flex section. It puts alot on stress on the turbo/manifold if you don't.
</TD></TR></TABLE> i have a t-25 on a hf mani do you think that is big/heavy enough to cause stress? (i have stock mounts and have not noticed a prob yet)
my revhard manifold cracked after only 2000 miles. I think it was because I wasnt using a flexpipe, only a ball and socket joint that may not have been sufficient.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> i have a t-25 on a hf mani do you think that is big/heavy enough to cause stress? (i have stock mounts and have not noticed a prob yet)</TD></TR></TABLE>
Its not the weight from the turbo, when there is no flex section and the motor is rocking back and forth, the turbo, manifold and downpipe are trying to "bend" the exhaust right behind the oil pan, sort of like a pivot point.
If you don't have a flex, its trying to lift the entire weight of the exhaust, when there is a flex, it enables it to give at that critical point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">my revhard manifold cracked after only 2000 miles. I think it was because I wasnt using a flexpipe, only a ball and socket joint that may not have been sufficient.</TD></TR></TABLE>
Same with mine. I'm using solid motor mount's now..
i didnt use a flex section on my ITR. i had stiff *** mounts and ran rubber hangers and used V band. So I guess that all helped it
The ball and socket joint has to actually function (i.e. move when it needs to), and has to be located in the correct spot (mine is where the stock one used to be), my setup has over 40K on it, no issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">hello everybody.
who's not running a flexpipe on DP\exhaust?
and why?
best regards moshik galimidi
no flexpipe, but i run tension spring bolts where dp connects to cat converter, just like you would have factory
and why?
i ran no flex pipe on my drag kit and a few runs on the twistys led me to a cracked down pipe. i fixed it and a few weeks later it cracked for a 2nd time this time in a different spot. I used the factory style spring bolts and donut for all of that. I switched to a flex pipe since and have been running the twistys for over a year now and no cracks. i vote flex pipe
If you don't have a flex, its trying to lift the entire weight of the exhaust, when there is a flex, it enables it to give at that critical point. </TD></TR></TABLE> ok thanks for the info
i just mocked up my dp with my arc welder, im gonna mig it tomorrow at work. im gonna run a 90deg from the flange and about a 3" of stright pipe and another 90deg and about a 7" of flex pipe,
pics tomorow
pics tomorow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote"> i suck dick. </TD></TR></TABLE>
Dude seriously , WTF is your problem.
</TD></TR></TABLE>Dude seriously , WTF is your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">Dude seriously , WTF is your problem. </TD></TR></TABLE>
lol... Flexpipe
lol... Flexpipe
wfocrx
14
Oct 31, 2007 01:17 AM
SolAssassin
Jun 20, 2006 08:18 PM
