Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Are wheel spacers potentially dangerous?
Old May 10, 2005 | 06:22 AM
Boostage's Avatar
Default Are wheel spacers potentially dangerous?
I am thinking of getting spacers so I can run 215 tires with no rubbing, but I cant help but wonder if spacers wont put additional stress on the studs causing them to break off in a bump o somehing.
Old May 10, 2005 | 06:47 AM
r2x's Avatar
r2x
Default Re: Are wheel spacers potentially dangerous? (Boostage)
Get longer studs when you get spacers then.
Old May 10, 2005 | 07:34 AM
Johnny Tran's Avatar
Default Re: Are wheel spacers potentially dangerous? (r2x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r2x &raquo;</TD></TR><TR><TD CLASS="quote">Get longer studs when you get spacers then. </TD></TR></TABLE>
that, and ensure you buy some 'decent' spacers.
My 'cheapest ones i could find' self destructed after 3ish sessions at VIR last year...and made for some nasty shaking and scary times.
Of course heat could have been an issue...my rotors (all 4) were scored and purple...all the way through the hats from slightly hard braking. LOL
Old May 10, 2005 | 07:39 AM
nonsense's Avatar
I'd find some that are hubcentric for your application. This will ensure that the spacer is being supported by the hub rather than the studs.
Old May 10, 2005 | 09:58 PM
FlyZlow's Avatar
Default Re: Are wheel spacers potentially dangerous? (nonsense)
I had spacers on my 350Z with extended lugs and never had any problems. It saw a couple track days and there was no noticable wear on the spacers or lugs. Just remember that the further you go out on the lugs, the more leverage the wheel has to exert force on them. However, to run 215's, I doubt you'd need a very big spacer for any car.
Old May 11, 2005 | 05:23 AM
Boostage's Avatar
Default Re: Are wheel spacers potentially dangerous? (FlyZlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlyZlow &raquo;</TD></TR><TR><TD CLASS="quote">I had spacers on my 350Z with extended lugs and never had any problems. It saw a couple track days and there was no noticable wear on the spacers or lugs. Just remember that the further you go out on the lugs, the more leverage the wheel has to exert force on them. However, to run 215's, I doubt you'd need a very big spacer for any car.</TD></TR></TABLE>
but what size do I need?
Old May 11, 2005 | 09:54 PM
FlyZlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">but what size do I need?</TD></TR></TABLE>
Uh .. I don't know. You haven't said what type of car you have, which rims and what size/offset, ride height, etc. Those are all factors. Are you sure you even need them? I have a set of 225 RA-1s that I run on my CRX occasionally and the only rubbing I experience with them is on the fender, so a spacer wouldn't help there. It will only help if you're rubbing on the inside or if you have brake caliper clearance issues.
- Scott
Old May 11, 2005 | 10:01 PM
Boostage's Avatar
- Scott</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1241180
Old May 11, 2005 | 10:06 PM
slammed_93_hatch's Avatar
you don't need spacers with those you will be fine
instrument
10
Oct 1, 2007 04:55 PM
Scotland:EF3
Apr 10, 2007 04:25 PM
Markis.
16
May 23, 2005 01:28 PM
gakkuken
21
Jan 10, 2005 02:28 PM
zRd#1
May 14, 2003 11:46 PM
