ls-vtec build going bad help!!!!
Old May 10, 2005 | 03:15 AM
Ls4thGen's Avatar
Default ls-vtec build going bad help!!!!
ok i built a obd0 ls-vtec in my ef hatch Pct's gsr head, and i started it up last nite after finish the build last nite, and for some reason its running as if the firring order is off an timming is off, but the firing order is correct and the timming is dead on.I dont know what else to look for.only on the #4 cyl. its acting like *** i put the plug wire on and it pops like the firing order is wrong and if i slowly pull the plug wire away from the plug it kinda runs normal.when i open the throttle body it pings alittle, lmk your opinion, thanx.
Old May 10, 2005 | 01:08 PM
caspers_hatch's Avatar
Default Re: ls-vtec build going bad help!!!! (Ls4thGen)
Need more info. What ecu?
Old May 10, 2005 | 02:54 PM
vw eater's Avatar
pic's..?
Old May 10, 2005 | 03:51 PM
Ls4thGen's Avatar
Default Re: (vw eater)
im going to take the **** back apart.i'll let u know, oh running chipped pr3
Old May 10, 2005 | 03:57 PM
Default Re: (Ls4thGen)
i had a simimlar problem, seemed like it was only running on three cylinders, i triple check everything, bought all new injectors, resistor pack, etc.....
All along it was a bad ecu...have someone to swap with?
Good luck
Old May 10, 2005 | 05:20 PM
lsvtecracer's Avatar
Default Re: (caspers_hatch)
check the valve lash again. A valve lash could be too tite.
Old May 11, 2005 | 02:01 PM
Ls4thGen's Avatar
Default Re: (lsvtecracer)
well i replaced the rings, silver stone plugs, and its running good, but this kid sold me a chopped ls Dist, and im detenating under load, i took my buddies Dist off his obdo ls-vtec an my car ran sooo good, time to ream this kids ***.
Old May 13, 2005 | 12:39 AM
Ls4thGen's Avatar
welp, another problem, fake jdm pistons where hitting the head found some new Pct's Oem picking them up today for 100 bucks
Old May 13, 2005 | 02:46 AM
LSVTEC 91 Civic's Avatar
Banned
Get these plugs from Advance...
NGK Stock no 4554, its an NGK Racing 8 V Power.
Old May 19, 2005 | 08:40 AM
Ls4thGen's Avatar
Default Re: (LSVTEC 91 Civic)
i got some silverstones the burn colder. going to cheack on my pistons at the machine shop!!wooo hooo
Dustin Hunt
Mar 31, 2012 02:22 AM
oldschoollove
14
Jul 19, 2009 03:20 PM
b18hondahb
Apr 20, 2008 03:17 PM
gunnerman
12
Oct 24, 2007 09:40 AM
