cars in limp mode, please help
Old May 9, 2005 | 04:27 PM
Crasian's Avatar
Default cars in limp mode, please help
hi peoples, i got my new motor in my car now and i started it up, seems like its in limp mode because it wont rev up past 3000 rpm and it seems really really boggy, i got 2 CEL 's one for 02 sensor and the other was a code 14 which is iacv. they both seemed plgged in rite but i tried to follow the wiring to the ecu and dont seem to be able to follow it too well.
What has me puzzled rite now is the reason why its in limp mode, these two problems shouldnt be causing it to do that. any help would be great peeps
oh yeah, car is a 93 civic coupe with a d16z6
Old May 9, 2005 | 04:32 PM
s2kkk's Avatar
Default Re: cars in limp mode, please help (FarOutCoupe)
Chipped ECU?
Old May 9, 2005 | 04:35 PM
Crasian's Avatar
nope, its all stock
Old May 9, 2005 | 04:56 PM
Crasian's Avatar
well doesn anyone know what causes a car to go into limp mode?
Old May 9, 2005 | 07:56 PM
Crasian's Avatar
help
Old May 10, 2005 | 05:39 AM
Crasian's Avatar
Old May 10, 2005 | 06:05 AM
bogus_ek's Avatar
Default Re: (FarOutCoupe)
wow... this sounds exactly like what i am going through right now. i highly doubt it is limp mode, but just to make sure start by getting rid of your check engine lights. i had the exact codes doing a obd I b18 into an obdII hatch. which o2 code is it? next check your timing. this is where i am at. really boggy, won't rev past 3000. take a timing gun to it. in my case, the car is running extremely retarded, and when you try to rev it, it just retards itself out until it almost dies. i would assume you're having the same problem, not really limp mode, cause neither of those two codes would cause the car to react that way... anyways bump for you cause i'm trying to find out too... here are some other suggestions i've been given in my thread
https://honda-tech.com/zerothread?id=1236085
Old May 10, 2005 | 06:08 AM
flood's Avatar
I would think that if it were in limp mode the CEL would flash or at least give you a trouble code worth while.
Where did the engine come from?
Agreed with above to check the timing. Could be mechanical problem and not the ECU.
Old May 10, 2005 | 06:42 AM
Crasian's Avatar
Default Re: (bogus_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogus_ek &raquo;</TD></TR><TR><TD CLASS="quote">wow... this sounds exactly like what i am going through right now. i highly doubt it is limp mode, but just to make sure start by getting rid of your check engine lights. i had the exact codes doing a obd I b18 into an obdII hatch. which o2 code is it? next check your timing. this is where i am at. really boggy, won't rev past 3000. take a timing gun to it. in my case, the car is running extremely retarded, and when you try to rev it, it just retards itself out until it almost dies. i would assume you're having the same problem, not really limp mode, cause neither of those two codes would cause the car to react that way... anyways bump for you cause i'm trying to find out too... here are some other suggestions i've been given in my thread
https://honda-tech.com/zerothread?id=1236085</TD></TR></TABLE>
yes, i read your thread too and im pretty sure its the exact same thing thats wrong with your car. i took mine around the block and it was beyond boggy, trying to get to 4th gear was hard and i only ended up getting to like 30 km/h. Crazy slow. anyways yeah when i rev the car up in the driveway, it wont really go beyond 2500 rpm and it will just rev rite nack down on its own and sound like it wants to stall, this car is making me so angry. I am gonna get my dad to come over maybe tmrw nite and chec k the timing for me
Old May 10, 2005 | 06:45 PM
Crasian's Avatar
Default Re: cars in limp mode, please help (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">I would think that if it were in limp mode the CEL would flash or at least give you a trouble code worth while.
Agreed with above to check the timing. Could be mechanical problem and not the ECU. </TD></TR></TABLE>
engine came from a buddy, it was running fine when it was taken out
Granny_shifter
18
Sep 17, 2012 08:08 AM
goldhatchie89
Aug 28, 2006 12:30 AM
EckoTech
Sep 30, 2005 08:43 PM
boostedcivichatchbacksi
Jun 6, 2004 10:58 AM
