High idle with no CEL
Old May 9, 2005 | 11:20 AM
1.8EG-T's Avatar
Default High idle with no CEL
My car, a 92 EG, was swapped over with a b18c. I removed hte FITV, for an str throttle body and rev hard mani. When i start the car, I have to hold the throttle, becuase of the FITV being gone. However when the car warms up. It idles around 2k and then rises on it's on to 3 k. It holds steady there until I hit the gas hard an quick, then it falls back to normal. It will hold here until I drive or hit the gas and it stays between 2k and 3k rpms...I have check for vacuum leaks...and am running out of ideas. Can you give me a bone and help me out, so I can get the car tuned in two weeks.
Old May 9, 2005 | 03:26 PM
1.8EG-T's Avatar
Default Re: High idle with no CEL (1.8EG-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8EG-T &raquo;</TD></TR><TR><TD CLASS="quote">My car, a 92 EG, was swapped over with a b18c. I removed hte FITV, for an str throttle body and rev hard mani. When i start the car, I have to hold the throttle, becuase of the FITV being gone. However when the car warms up. It idles around 2k and then rises on it's on to 3 k. It holds steady there until I hit the gas hard an quick, then it falls back to normal. It will hold here until I drive or hit the gas and it stays between 2k and 3k rpms...I have check for vacuum leaks...and am running out of ideas. Can you give me a bone and help me out, so I can get the car tuned in two weeks.</TD></TR></TABLE>
Old May 9, 2005 | 04:38 PM
rainforest's Avatar
did it start after you removed the fitv if so you answered your own question
realrawjbizz
Jul 5, 2011 11:21 AM
DeLSoLRo
20
Apr 23, 2011 10:06 AM
jcfreibert
10
Nov 23, 2007 10:51 AM
cbcrx87
Aug 13, 2006 10:32 AM
qstorm
Aug 16, 2004 04:07 PM
