Please tell me if my alignment specs are good, I can't read them.
Old Feb 3, 2002 | 11:43 PM
nEoMuGen's Avatar
Default Please tell me if my alignment specs are good, I can't read them.
Maybe I am mentally challenged, but the only reliable source I have about alignment is Helm's manual and I just can't use that information to analyze this spec sheet:
I've specifically asked those people if they have my car's factory specs in their machines' database and they said yes. But it seems like they are using regular Integra's data....my car is still abit loose, maybe it's the new tires but I expected the car should be firm as the first day I got her.
[Modified by nEoMuGen, 8:44 AM 2/4/2002]
Old Feb 4, 2002 | 12:03 AM
tjtruong's Avatar
New User
Default Re: Please tell me if my alignment specs are good, I can't read them. (nEoMuGen)
to be honest, it looks ok .. Everything is with in allowance. Type Rs stock have some sort of negative camber in the front so you'll be ok.
tj
Old Feb 4, 2002 | 12:30 AM
nEoMuGen's Avatar
Default Re: Please tell me if my alignment specs are good, I can't read them. (tjtruong)
Thanks! Because the Helm's manual confused me a bit.....
Old Feb 4, 2002 | 04:53 PM
nEoMuGen's Avatar
Any other re-assurance?
Old Feb 4, 2002 | 05:24 PM
Warren's Avatar
Wrong-Way Wang
Have you ever been in an accident? Your caster is off at the front right.
Warren
Old Feb 4, 2002 | 05:31 PM
nEoMuGen's Avatar
Default Re: Please tell me if my alignment specs are good, I can't read them. (Warren)
I hit a small tree on my front left (driver), but there are no major damage except that my headlight can't aim up anymore. There's never been any impact on the front right (passenger side).
Why didn't the tech adjust it...it can't be adjusted?
[Modified by nEoMuGen, 2:31 AM 2/5/2002]
Old Feb 4, 2002 | 06:31 PM
Warren's Avatar
Wrong-Way Wang
Caster can't be adjusted, and it's wrong in the bad way. That wheel is basically standing straight up (side view), not tilted back, like on a bike. It'll be a little more lively than it should be, but it'll be okay.
There's quite a bit of stock side to side stiffening on an ITR, so when you whack one side, the other can get screwed up.
Warren
Old Feb 4, 2002 | 09:52 PM
nEoMuGen's Avatar
What do I need to replace to have that caster fix?
Old Feb 4, 2002 | 09:58 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Damn this is a lot like the problem I'm having. Thanks guys.
D50boy
Honda CR-V & Element
May 9, 2018 03:39 PM
allanonjj
Sep 9, 2012 09:45 PM
cambopheonix56
16
Sep 11, 2005 02:19 PM
B18aTegra
Aug 20, 2002 10:42 PM
bus stop
Apr 9, 2002 06:43 PM
