running boost on ITR block with GSR head
Old May 9, 2005 | 07:29 AM
Nextelbuddy's Avatar
Default running boost on ITR block with GSR head
well the car i currently have i swapped out the 133k gsr bottom end for a 32k ITR block and my gsr head i just used CTR cams with rocket motorsport dual valve springs and titanium retainers with new valve stem seals..
from my searching a ITR block with gsr head should ield some where around 11:1 compression... when i did a compession test the numbers inorder from DIZZY to TIMING BELT side was 260 - 250 - 250 - 250 so the motor sounds healthy and runs fine.. i want to turbo this motor eventually and just turbo this motor now until i build it for boost later... but the higher compression worries me..
would this motor be ok with low boost with good tuning? or is that nto a good idean and just wait till i build the motor with slightly lower compression pistons..?
Old May 9, 2005 | 07:33 AM
Evanmb44's Avatar
as long as you get it tuned properly for low boost you will be fine until you build the motor.
happy boosting
Old May 9, 2005 | 08:05 AM
Default Re: (Turboaddict)
thats what ui was hoping.. maybe mroe will chime in with their thoughts as well.. thanx
Old May 9, 2005 | 08:46 AM
RacerXI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict &raquo;</TD></TR><TR><TD CLASS="quote">as long as you get it tuned properly for low boost you will be fine until you build the motor.
happy boosting</TD></TR></TABLE>
You might throw in a head gasket for some safety factor.
Old May 9, 2005 | 09:33 AM
SSBPGSR's Avatar
Default Re: (RacerXI)
a friend of mine is boosting 8psi on his JDM ITR motor with stock internals/hg. the higher comp ratio just gives the tuner less space to mess up. lower comp you have a larger margin of error. as long as you bring it to a good tuner, you will be fine on low boost.
good luck
xKAMILxEK
Apr 21, 2010 09:41 AM
b18-crx
Jul 11, 2009 02:00 PM
NAEK
Aug 22, 2005 12:24 AM
lazyvietboi
Nov 5, 2001 07:44 PM
