Bseries hydro tranny parts compatible?
Old May 9, 2005 | 01:39 AM
CRAZYEG9's Avatar
Default Bseries hydro tranny parts compatible?
Are all hydro Bseries syncros compatible cause I have a junk/bad GSR tranny what do I need to do to put the Gsr 4.4 final in the LS tranny. I also want to put 3,4,and 5th gears in. Explain this swap. I want to keep using the LS syncros. Thankyou
Old May 9, 2005 | 03:20 AM
CRAZYEG9's Avatar
bump for an answer
Old May 9, 2005 | 08:46 AM
CRAZYEG9's Avatar
Anyone?
Old May 9, 2005 | 08:48 AM
JDMlyfestyle's Avatar
Yes all b series parts including transmission are innerchangeable.
It is very common for road racers to swap out gears and mix and match from different trannies.
Common setup i see is the ITR LSD with 4.7 FD 1-4 B16 gears and LS 5th gear.
Old May 9, 2005 | 08:51 AM
CRAZYEG9's Avatar
Default Re: (JDMlyfestyle)
Okay are the syncros the same cause I wanna take 3,4, and 5 from the GSR but still use the LS sycros cause the GSRs are bad. Also to usw the final drive do I have to use the ring gear and pinion(I think I'm saying it right) and diferential. Thanks.
Old May 9, 2005 | 10:01 AM
CRAZYEG9's Avatar
Bump
jdmfoose
Transmission & Drivetrain
Nov 8, 2013 07:09 PM
Hartattack
Jun 3, 2008 05:00 PM
dem0nk1d
Jan 20, 2007 12:37 PM
MRXMUFFIN
May 9, 2005 09:22 PM
lysergican
May 6, 2002 07:58 AM
