MSD Blaster 2 leaking oil ?
yes i they aren't mounted correctly they will start to leak.i have to replace mine today also, cause i did not fill like mounting like i should have, after awhile the vibrations will cause the casing to crack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bounty359 »</TD></TR><TR><TD CLASS="quote">dude you can get a msd ss coil for 50 bucks if your coil is leaking oil????? get a new one</TD></TR></TABLE>i'm not concerned about cost just wanted to know why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx34 »</TD></TR><TR><TD CLASS="quote">yes i they aren't mounted correctly they will start to leak.i have to replace mine today also, cause i did not fill like mounting like i should have, after awhile the vibrations will cause the casing to crack.</TD></TR></TABLE>how should it be mounted. mine sits on its side
the shop owner that sold me mine said it should be straight up and down. also has any body had starting problems with there msd.last night my car would not start so i had somebody else crank it over and i noticed that the top of the coil and the negative post were arching like crazy, so i had to put electrical tape to get it home wile it was bucking on me the whole time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si »</TD></TR><TR><TD CLASS="quote">sounds crazy but i noticed oil coming out of the coil. anyone ever see this ?</TD></TR></TABLE>
The coil is filled will oil to act as an cooling agent and dampener for vibrations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">but what causes this to happen? I have mine mounted a little awkward...</TD></TR></TABLE>
It's a sealed unit.... when it leaks, it's time to replace it. If it's good, you can even mount it upside down if you like, mines is mounted at 90degree angle.
