vtec is busted
Old May 8, 2005 | 02:51 PM
JDMFREAK2002's Avatar
Default vtec is busted
Just started working on my EF that has been sitting outside for about a year. Has a b16a1. Starts and moves but....
Vtec is not engaging, checked the solenoid its fine. Oil level is up and the temp gauge is showing hot when i am trying to get it to kick. Not sure where to go from here. Yes I've searched but haven't found anything that is of any use
Also, when it starts it idles at about 3-4k then tapers to around 1500. Checked all the vacuum lines, they're in good shape????
Any and all informed help is fantastic
Old May 9, 2005 | 06:36 AM
tgreaves's Avatar
Default Re: vtec is busted (JDMFREAK2002)
I would check the vtec noid filter.. Also you can hook a small light up to the vtec noid and run it inside the cabin to make sure that the ecu is actually turning on the vtec..
Old May 9, 2005 | 03:18 PM
mugenracer's Avatar
yeah i'd go along with that too...if the motor has been lying for a year then the gauze filter in the solenoid is possibly clogged with sludgey oil and would need replacing or cleaning before trying anything else
Old May 9, 2005 | 04:45 PM
Default Re: (mugenracer)
sweet ill give that a try. thanks for the help so far...hopefully thats all i need
Old May 10, 2005 | 03:00 PM
Default Re: (JDMFREAK2002)
Well the filter is fine. If i remember correctly you need to read proper oil pressure for it to engage. So i guess swap out that sensor. Is there anything else that would cause it not to work aside from a bad ECU. Possibly some kind of RPM sensor. Ive been out of the game for a while now and my previous knowledge seems to be failing me.
Thanks again
civic_b20vtec
Jun 25, 2013 05:27 AM
BDM
Oct 20, 2009 09:02 AM
stwokay
May 21, 2009 06:36 PM
v.i.gsr
Mar 19, 2007 01:26 PM
rollindelsol
11
Dec 9, 2006 04:53 PM
