OIL CHANGE
Old May 8, 2005 | 11:49 AM
meanTheDope's Avatar
Default OIL CHANGE
I just bought a 2005 r6 and its past 600 miles and i need an oil change. can i use regular 10w40 synthetic motor oil...or does it specifically have to be motorcycle oil? all replys are greatly appreciated.
thanks
-cN
Old May 8, 2005 | 11:53 AM
Ag-Eng's Avatar
Default Re: OIL CHANGE (meanTheDope)
At 600 miles, you need to consult your owners manual for the proper oil to put in it.
I would NOT, repeat NOT put synthetic in yet. General thoughts are to wait until around 2k miles before going synthetic.
Old May 8, 2005 | 11:59 AM
Default Re: OIL CHANGE (Ag-Eng)
why not?
Old May 8, 2005 | 01:02 PM
Kista20's Avatar
you can as long as it's synthetic motorcycle oil. Motorcycle oil and motor oil are 2 different things. Each is made up of their own chemical properties.
Old May 8, 2005 | 02:01 PM
Bud's Avatar
Bud
New User
Default Re: OIL CHANGE (Kista20)
Motorcycle oil is different in that it can withstand double your car's rpm without breaking down.
Nothing wrong with going to synthetic after 600 miles. A lot of manufacturers suggest it. I have had zero problems using full synth since I completed break-in.
Old May 8, 2005 | 04:23 PM
Default Re: OIL CHANGE (Bud)
ok guys...i got castrol synthetic r4 motorcycle oil..but the freakin oil filter is hard to come off.
Old May 8, 2005 | 04:25 PM
marmaladedad's Avatar
What oil filter wrench are you using? There's one for sale at Griot's Garage which works REALLY well. I'm sure there's a cheaper, similar version out there somewhere.
As for motor oil, I believe the general consensus is anything is fine, as long as it's not energy conserving.
Old May 9, 2005 | 10:41 AM
Default Re: (marmaladeboy)
ok got everything done...everything you need to do an oil change is in the tool kit...but the 17mm wrench sucks...so use a rachet with a breaker bar to get the oil drain bolt...and a oil filter wrench to losen the oil filter...now that i did the oil change the bike runs/feels better...thanks for all the help guys.
Old May 9, 2005 | 10:43 AM
You won't need to tighten the oil filter too much when installing it. Just as tight as you can get it with your hand, then a little bit more.
Old May 9, 2005 | 12:16 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (meanTheDope)
Breaker bar? Oil filter wrench?
Good grief. My drain bolt is only TQ'd to 14 ft/lbs and the oil filter, once the gasket touches the mounting surface give it 3/4 (270 degrees) of a turn. No leaks and no wrench required.
Edit: 40, 14 sounds the same in your head when you are typing fast.
Modified by Mr Hammond at 6:27 PM 5/9/2005
Old May 9, 2005 | 12:30 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">My drain bolt is only TQ'd to 40 ft/lbs </TD></TR></TABLE>
I think mine is like 14 lbs or something. Hope that's a typo or I see some stripped threads in your future
Old May 9, 2005 | 01:22 PM
Bud's Avatar
Bud
New User
Default Re: (RebornGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RebornGSR &raquo;</TD></TR><TR><TD CLASS="quote">
I think mine is like 14 lbs or something. Hope that's a typo or I see some stripped threads in your future </TD></TR></TABLE>
+1 mine is only to 20
Old May 9, 2005 | 02:29 PM
Mr Hammond's Avatar
a/k/a Jomo
:sigh: Fixed. That's what I get I guess.
Hey they sound the same in your head. Too bad spell check can't fix stupidity errors.
Old May 9, 2005 | 02:30 PM
.Ash's Avatar
castrol gtx is a good non-syn oil to run; not energy conserving. 40ft/lbs is a lot; like pan cracking torque...
Old May 9, 2005 | 05:29 PM
Default Re: (usdmPC3)
it was the first oil change...so thats why i think everything was on so tight
k3ntegra
May 19, 2015 05:10 PM
dylokjai
Nov 7, 2004 06:36 AM
Behan
Sep 9, 2003 05:10 AM
mickey513
Oct 5, 2001 10:11 AM
TypeR01-424
Aug 17, 2001 07:51 AM
