CTR OR ITR PISTONS
Old May 7, 2005 | 10:34 PM
need4hondaspeed's Avatar
Default CTR OR ITR PISTONS
This is probably a dumb question. Anyway which pistons would be better to use in a b16, the itr or ctr?And with LS rods right for either would be better? Thanks for you input.
need4hondaspeed@yahoo.com
Old May 7, 2005 | 10:48 PM
Kendall's Avatar
ITR pistons will cause you to lose compression, CTR pistons will cause you to gain compression. LS rods will cause either to have territorial disputes with the cylinder head.
Old May 8, 2005 | 09:45 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: CTR OR ITR PISTONS (need4hondaspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by need4hondaspeed &raquo;</TD></TR><TR><TD CLASS="quote">This is probably a dumb question. Anyway which pistons would be better to use in a b16, the itr or ctr?And with LS rods right for either would be better? Thanks for you input.
need4hondaspeed@yahoo.com</TD></TR></TABLE>
Make sure you use an h23 crank and you will have a sic stroker motor
Old May 8, 2005 | 04:47 PM
Default Re: CTR OR ITR PISTONS (PURPLETERROR)
so what an h23 crank ctr pistons and ls rods. Plus have everything balanced. or is the h23 crank a joke.
Old May 8, 2005 | 06:26 PM
how is ITR pistons going to make you lose compression?
Old May 8, 2005 | 09:09 PM
1993acuraintgralsvtec's Avatar
for real?
Old May 9, 2005 | 12:40 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by need4hondaspeed &raquo;</TD></TR><TR><TD CLASS="quote">how is ITR pistons going to make you lose compression?</TD></TR></TABLE>
There is much you need to learn concerning compression height.
Old May 9, 2005 | 05:27 AM
mmuller's Avatar
Mad Scientist
Default Re: CTR OR ITR PISTONS (Kendall)
pr3 pistons have a higher dome than p73's (.098'' vs. .070); compression height is also .01'' diference between the 2, compression height favors the p73; in regards of compression
Justin32714
Mar 24, 2011 04:27 PM
CaseBone
32
Apr 3, 2007 05:15 AM
WhiteDC4
Apr 6, 2004 09:32 PM
AudioXtremes
Nov 6, 2002 02:48 AM
