B18c turbo which throttlebody?
Old May 7, 2005 | 08:21 PM
crxsiperf's Avatar
* B A N N E D *
Default B18c turbo which throttlebody?
Gsr engine with victor x manifold , turbo and hondata , 3 inch downpipe , which throttlebody should i use in trms of size. I'm getting an STR but not sure which size to get . Im getting spoolinperformance 2.5" charge pipes so im thinking of using the 688 mm since its about 2.6" but i have heard of poeple using up to a 74mm . Which is best to use, i still wanna drive this thing on the street .
Thanks
Old May 7, 2005 | 08:28 PM
Deathwish's Avatar
how much HP do you plan on puttin out?
Old May 7, 2005 | 08:33 PM
_gurusan_'s Avatar
Default Re: (Deathwish)
Is your motor built?
Since you have the JG IM the smallest you should put on is 65mm...but that's overkill if your puttin under 300whp IMO
Old May 7, 2005 | 10:51 PM
T4eg's Avatar
Default Re: B18c turbo which throttlebody? (crxsiperf)
i say to stay with stock TB and put the $$ into other areas where u will gain more.
Chris
Old May 7, 2005 | 11:14 PM
The DX Rex's Avatar
This is exactly where you need to look ......... http://www.maxbore.com/
oldskoolracer
Engine Management and Tuning
15
Feb 16, 2014 07:00 AM
murtnabila
Mar 12, 2006 02:30 PM
H22civatch
Jan 1, 2006 04:52 AM
asianspeed
Jan 9, 2003 04:54 PM
