please look at my rod bearings ,
Old May 7, 2005 | 06:49 PM
B18C1CYA's Avatar
Default please look at my rod bearings ,
well here they are , this is #1 rod cap and bearing , also can you tell me what this corrosion looking stuff is on them ???
here is # 2 wich stretched and spun
and here is # 3 rod cap and bearing looks the same as #1
and finaly # 4 looks like the others
so please let me know what is wearing is on them , cus i have always had a worrie that my sleeves where leaking ,
Old May 7, 2005 | 07:19 PM
CRXDrew's Avatar
bump for you because i've never seen anything like that. Oil starvation?
Old May 7, 2005 | 07:29 PM
B18C1CYA's Avatar
Default Re: (CRXDrew)
no never lost pressure , and this motor only had under 4000 miles on it with acl bearings
Old May 7, 2005 | 07:32 PM
Wideopentuning's Avatar
Default Re: (B18C1CYA)
Any spots in your map where you know you run way richer than you should? Possible fuel in the oil.
Old May 7, 2005 | 07:46 PM
Adi Radoncic's Avatar
On Fire!
Default Re: (Wideopentuning)
I know the big end on those eagle rods when you buy them is out of spec about 90% of the time...
Old May 7, 2005 | 07:49 PM
B18C1CYA's Avatar
Default Re: (newgsr)
realy well i didnt build it , i had got the block built and sleeved by earl ,
Old May 7, 2005 | 07:53 PM
SpeedDreamz.com's Avatar
That looks like the coating coming off the bearings. Did the bearing actually spin inside the cap? It must be some type of oiling issue.
Old May 7, 2005 | 07:56 PM
B18C1CYA's Avatar
Default Re: (SpeedDreamz.com)
like i said oil pressure was fine at all times , then the knock started after a pull last night , then the pressure was lower , the rods where eagles so i guess they all could have stretched and spun ,
Old May 7, 2005 | 07:57 PM
mrDFWmechanic's Avatar
damn that sux i remember seeing that dyno video of your motor not too long ago and ****'s already happening. how'd you know something was wrong with the bearings ??
Old May 7, 2005 | 08:01 PM
b00stedbyFastrax's Avatar
Default Re: please look at my rod bearings , (B18C1CYA)
[QUOTE=B18C1CYA]well here they are , this is #1 rod cap and bearing , also can you tell me what this corrosion looking stuff is on them ???
[img]http://www.we-todd-did-[QUOTE=B18C1CYA]well here they are , this is #1 rod cap and bearing , also can you tell me what this corrosion looking stuff is on them ???
QUOTE]
i had the same problem with a JG built block about 3 years ago (ACL bearings). when i had the block torn apart, the mains was just like yours. don't know what may have caused it, but since then i did the rebuilt myself using honda bearings. after two years of abuse, did a ring job and checked the bearings for wear. all bearings on the block was in good condition, and only one main cap bearings had a liitle excess wear. at that time I was making 515 whp.
B18C1CYA's Avatar
Default Re: (iROCKtheSOHC)
well the knock started last night , mind you the motor was fine for the almost 4000 miles it had on it until last night when i did i nice pull , also keep in mind that this was only on low boost wich i made like around 440 whp on , well i did the plug wire trick and when i found the one where the knock stoped i decided to pull some rod caps
Old May 7, 2005 | 08:03 PM
what's the plug wire trick ?
B18C1CYA's Avatar
Default Re: please look at my rod bearings , (b00stedbyFastrax)
so you had main bearing issues ?? cus i dont know if i have any of them yet
Old May 7, 2005 | 08:04 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">what's the plug wire trick ? </TD></TR></TABLE>
you pull them off one at a time with the motor running and if the knock gos away or gets less then it is in the bottom end
Old May 7, 2005 | 08:05 PM
boosted hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wideopentuning &raquo;</TD></TR><TR><TD CLASS="quote">Any spots in your map where you know you run way richer than you should? Possible fuel in the oil.</TD></TR></TABLE>
Vaccuum was tuned at 15:1 and boost was tuned at 11.5:1. I went through and tuned every boost scaler at each boost scaler instrument in the Hondata software, both high and low cam, so there is nowhere it could possibly be running too rich.
This isn't the first time I've seen an engine spin all the rod bearings with Eagles.
Old May 7, 2005 | 08:07 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">That looks like the coating coming off the bearings. Did the bearing actually spin inside the cap? It must be some type of oiling issue.</TD></TR></TABLE>
also the tab is not ripped of like on the #2 rod bearing , so i think maybe they didnt spin , i dont know ,
could coolant in the oil do this ?????? cus i have always though i had a sleeve leak
Old May 7, 2005 | 08:09 PM
damn that suk to have a sleak leak, did you o-ring the motor
Old May 7, 2005 | 08:11 PM
B18C1CYA's Avatar
no i was told it didnt need it with the stepped deck ,
Old May 7, 2005 | 08:23 PM
Garcia-Racing's Avatar
I think its ok for the bearings to look like that. After a fresh build and maybe 10 dyno pulls mine come out just like that. Turbo engines run so rich that some fuel will blow by the rings and contaminate the oil. But it is normal. I don't think the damage to your bearing had anything to do with the spotting on the other bearings.
Old May 7, 2005 | 08:28 PM
tony1's Avatar
Default Re: (Garcia-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garcia-Racing &raquo;</TD></TR><TR><TD CLASS="quote">I think its ok for the bearings to look like that. After a fresh build and maybe 10 dyno pulls mine come out just like that. Turbo engines run so rich that some fuel will blow by the rings and contaminate the oil. But it is normal. I don't think the damage to your bearing had anything to do with the spotting on the other bearings.</TD></TR></TABLE>
Uh, no, sorry. That's not normal. I don't know what it is, but it's not normal. It's hard to say if it was an oiling issue, clearance issue, or rod issue. Either way, it's fucked. Replace the crank with a new one, use HONDA bearings, and get some good rods...
Old May 7, 2005 | 08:30 PM
B18C1CYA's Avatar
Default Re: (tony1)
yup that is all in the works as i type , lol
Old May 7, 2005 | 08:33 PM
damn, maybe it was caused by those eagle rods lol
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Uh, no, sorry. That's not normal. I don't know what it is, but it's not normal. It's hard to say if it was an oiling issue, clearance issue, or rod issue. Either way, it's fucked. Replace the crank with a new one, use HONDA bearings, and get some good rods...</TD></TR></TABLE> You've never seen that before?
Old May 7, 2005 | 08:35 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">damn, maybe it was caused by those eagle rods lol</TD></TR></TABLE>
well you can see in the one pic how the cap is stretched out of round , iam holding the bearing tight to one side of the cap and there is almost a 1/16" gap on the other side , not cool
Old May 7, 2005 | 08:38 PM
I run Crowers with ACL's and my motor does this right away. But I have gone a full season like that with no bearing problems. But Tony 1 is the man. I'm not trying to argue with him.
