help with 4 wire 02 sensor
Old May 7, 2005 | 04:51 PM
b18cEF9's Avatar
Default help with 4 wire 02 sensor
so i converted to obd1, im throwing codes 20, and 41. code 20 is electrical load detector, and 41 is primary oxygen. the colors of the wire on my 02 are gray, black, and 2 whites. can anyone tell me wires are for what. (ground, power) blah blah
Old May 7, 2005 | 04:53 PM
ne3ek's Avatar
Default Re: help with 4 wire 02 sensor (b18cEF9)
black is ground, gray is o2 signal, white/white are -/+ for the heating element
Old May 7, 2005 | 05:11 PM
b18cEF9's Avatar
Default Re: help with 4 wire 02 sensor (ne3ek)
thanks, would having the ground for the 02 sensor hooked up to wrong wire on the conversion harness cause me to throw code 20? say if the ground was hooked up to the signal wire?
Old May 7, 2005 | 05:27 PM
ne3ek's Avatar
ya the all of them should be wired up, but ya if they are mixed the o2 wont throw the correct signal. An o2 signal is very sesitive too
Old May 7, 2005 | 05:31 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD95hatch &raquo;</TD></TR><TR><TD CLASS="quote">
so the black wire is the only one needed to be pluged into the ECU?
Modified by JD95hatch at 12:43 AM 3/16/2005</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">I think what Relic1 is saying is that since you already have a wire for the O2 signal (from your single wire O2), just cut off that connector and solder it to the 4-wire O2 signal output (the white wire).
You will need to source a switched +12v for the heater power (Relic1 is saying grab that from the junction plug).
You will need to source a ground for the O2 signal (Relic1 is saying grab that from the thermostat housing ground that already exists).
You will then need to run just one wire, the heater control, back to the ECU so that the ECU can control the heater section of the O2.
Viola' - you're done.
*You are using an ECU that uses a 4-wire O2, correct?*</TD></TR></TABLE>
b18cEF9's Avatar
but would it cause me to throw code 20? remember code 20 is electrical load detector
Old May 8, 2005 | 10:16 AM
b18cEF9's Avatar
anyone
Old May 8, 2005 | 10:27 AM
HatchBox's Avatar
Skoobie no more...
why dont you wire it up and see if it throws the code?
Old May 8, 2005 | 12:32 PM
96-EJ6 B18C's Avatar
Yo Justin, check out this link...
https://honda-tech.com/zerothread?id=468260
Just scroll down to where it says "Code 20" then open the pics, they are flow charts to determine what the problem is. Good luck, and If you can't get it figured out just give me a shout, I'll give you a hand.
Old May 8, 2005 | 03:57 PM
b18cEF9's Avatar
Default Re: help with 4 wire 02 sensor (96-EJ6 B18C)
nick that just confused the **** outtta me, ill go and ***** around with it
Old May 8, 2005 | 04:12 PM
HatchBox's Avatar
Skoobie no more...
Old May 8, 2005 | 04:36 PM
b18cEF9's Avatar
Default Re: help with 4 wire 02 sensor (HatchBox)
yes thats what confused me
edit: i always thought you remove the ecu fuse to reset the ecu
Old May 8, 2005 | 04:41 PM
HatchBox's Avatar
Skoobie no more...
go through the steps, i dont see how that is confusing. lol
Old May 8, 2005 | 04:45 PM
b18cEF9's Avatar
im half retarded , i dont like trouble shooting
pretty sure i have a bad electrical load detector, when i was doing my obd1 conversion, i forgot to disconnect the battery, and when i was soldering, couple wires shorted/grounded out, thats the only thing i ca think of
anyone know whast the asking price for a ELD is?
Modified by b18cEF9 at 2:24 AM 5/9/2005
civicguy395
Oct 30, 2012 03:52 PM
crxattack
Mar 24, 2006 02:44 PM
eastbay92cx
Aug 30, 2004 06:51 AM
elmalouno
11
Aug 18, 2004 09:06 AM
xmd
Oct 12, 2003 10:38 AM
