Is there a gasket here?
Old May 7, 2005 | 04:14 PM
Attoir's Avatar
Default Is there a gasket here?
So, I've got an oil leak on my JDM H22A. Took off the intake manifold to get a better look, and this is what I found.
(Black plastic is the timing belt cover, the port you see is the driver side intake port.)
#1.) Lots of oil here, it's the most saturated area. I also *believe* I saw a few drips squeezing out of the area the arrow is pointing to. Not 100% sure tho'.
That is the water pump, right? Are there oil passageways in there? What is the gasket called I need to replace, if that's the problem?
#2.)A few people suggested the head gasket, but this is the only area around the HG that appears damp w/ oil. Not to mention I have been getting no oil in my coolant, or vice-versa.
Any ideas will be greatly appreciated!
Old May 7, 2005 | 05:52 PM
Status Sean's Avatar
Default Re: Is there a gasket here? (Attoir)
if i can remember rite i had a problem like this with my gsr mota ! and theres something rite there that make the oil flow through there ! i jus got some gasket sealer on there to act as a gasket and it never leaked again ! its hard to tell from the pic hopefully i helped a little
Old May 7, 2005 | 07:27 PM
EG6 SiR's Avatar
Cam seal maybe?
Old May 7, 2005 | 07:32 PM
Luserkid's Avatar
Default Re: Is there a gasket here? (EG6 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR &raquo;</TD></TR><TR><TD CLASS="quote">Cam seal maybe?</TD></TR></TABLE>
Doesnt look like it, this is a little low for a cam seal. You might need to take off the plastic cover to see where its really coming from.
Old May 7, 2005 | 08:07 PM
snowman0520's Avatar
samething is happening on my b7, i would say cam seal or valve cover gaskets since its pretty much the only place where oil can come from up ther
Old May 7, 2005 | 08:16 PM
mrDFWmechanic's Avatar
it would have to be coming from somwhere up top maybe a valvecover gasket ?? can you take more pics of the area around it
Old May 7, 2005 | 08:52 PM
EG6 SiR's Avatar
Default Re: Is there a gasket here? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Doesnt look like it, this is a little low for a cam seal. You might need to take off the plastic cover to see where its really coming from. </TD></TR></TABLE>
It could be going behind the plastic cover and seeping down the side of the head and going to the spot that is pictured. Also, it could be the valve cover seal, but you would be able see where its leaking. So my vote is still cam seal. But like Luserkid said, take off the plastic cover off and check it out.
Old Aug 2, 2005 | 07:03 PM
ridewhencan's Avatar
So what did you find out? Was it the cam seal?
Old Aug 2, 2005 | 07:31 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Is there a gasket here? (ridewhencan)
My guess is either the water or oil pump.
B20VSi2000
May 16, 2016 04:38 AM
elmejor
14
Dec 12, 2012 02:30 AM
93lude4live
Sep 21, 2008 12:52 PM
hybrid_vtec
Feb 7, 2005 06:53 AM
Jonathan_ED3
Apr 11, 2003 09:02 PM
