knock sensor and ect
Old May 7, 2005 | 02:09 PM
crx-treme's Avatar
Default knock sensor and ect
i finished my b16 crx swap it starts and im throwing codes 14 and 6. these are knock sensor and engine coolant temperature sensor. i used a hasport jumper harness, and soldered everything. i rechecked everything everything seems to be in place. is there a way to check that the wires a re connected by a voltmeter? or should i just disconnect the wires and resolder? also, with the ect code, does that mean my ecu doesnt know when the engine is overheating or not? i ask cuz i wanted to run it for a while to see if the fan turns on. HELP PLEASE sorry 14 is intake control what is that caused by?
Modified by crx-treme at 3:20 PM 5/7/2005
Old May 7, 2005 | 02:14 PM
Burlyirishdude's Avatar
Default Re: knock sensor and ect (crx-treme)
ok the ECT sensor is prolly bad. I had the same thing dump out on my motor. Just go to any junkyard or find a Dealer and pay 40$ for it....
as for the knock sensor....
Old May 7, 2005 | 02:27 PM
eda6's Avatar
Default Re: knock sensor and ect (Burlyirishdude)
Continuity check those two circuits and make sure they go to the correct pin at the ecu.
If that's good check the sensors.
Old May 7, 2005 | 02:30 PM
crx-treme's Avatar
ok 14 is air intake control not knock sensor sorry. what is that caused by? the ect is at the back of the block, underneath the tb right? it has two wires going to it correct? thanks
Old May 7, 2005 | 03:36 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote"> the ect is at the back of the block, underneath the tb right? it has two wires going to it correct? thanks</TD></TR></TABLE>
ect is under the distributor and has a plug with red/whi and grn/whi wires.
https://honda-tech.com/zerothread?id=468260
Old May 7, 2005 | 04:34 PM
1gEF-8's Avatar
14 is eacv.
Old May 7, 2005 | 04:37 PM
1gEF-8's Avatar
Default Re: knock sensor and ect (1gEF-8)
try cleaning the eacv. had a 14 before (eacv filter was clogged)i flushed the **** out of is with brake cleaner.
Old May 7, 2005 | 04:54 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote">ok 14 is air intake control not knock sensor sorry. what is that caused by? the ect is at the back of the block, underneath the tb right? it has two wires going to it correct? thanks</TD></TR></TABLE>
The ect is on the head near the vtec, make sure you don't got those plugs switched up, up there. A few can be interchanged. Also same thing with the iacv, it can be switched with another plug causing a code.
Old May 7, 2005 | 11:18 PM
crx-treme's Avatar
Default Re: knock sensor and ect (90blackcrx)
but now im confused the eacv looks like the thing i hooked one of the 4 vtec wires to? i thought it was the knock sensor?? now im really friggin confused
so maybe the two are switched? i didnt think any plugs were the same.....well find out tomarrow
hondatech is way better then automotive forums!!!
thanks for the replys, im itching to feel vtec lol
Old May 7, 2005 | 11:54 PM
If I said the plugs were the same, all I ment was they could be interchanged and clip into each other and you would never know. Just like the vtec sensor can be cliped into the ect sensor.
IACV a.k.a eacv
Old May 8, 2005 | 12:05 AM
crx-treme's Avatar
where is the knock sensor? i have knock sensor plug on my hasport vtec harness plugged into the back of the throttle body, in pictures that looks like the iacv, so if these are interchangable that could solve the problem of iacv/eavc.... and u said the vtec and ect could interchange, so my guess is all these plugs are interchangable.... sorry for the dumb questions im just frustrated and want to drive my car ive been waiting way too long.... but tomarrow ill see if these are interchangable. THANks
Old May 8, 2005 | 07:08 AM
crx-treme's Avatar
ok i just went out and switched a vtec plug with ect, and cel went away. but i cant find anything that can be switched with the iavc where is the knock sensor
Old May 8, 2005 | 09:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote">ok i just went out and switched a vtec plug with ect, and cel went away. but i cant find anything that can be switched with the iavc where is the knock sensor </TD></TR></TABLE>
Told ya , sure you don't have like the intake air temp sensor switched up. I know for a fact another plug back there could be switched up with the iacv.
Old May 8, 2005 | 12:27 PM
PURPLETERROR aka BIGMATT's Avatar
the knoxk sensor is in the engine block right under the intake manifold, you really cant miss it, it will be above the oil filter
Old May 8, 2005 | 06:22 PM
Sneaky Ef's Avatar
it is, rather hard to get to/see when the motor is in the car.
Old May 8, 2005 | 11:21 PM
crx-treme's Avatar
Default Re: (Sneaky Ef)
well yes it is hard to see when engine is in the car, and hard to diconnect/connect with one hand....i found the problems. the knock sensor, iacv and theres one more plug on fourth(or third) runner on intake mani, all these can interchange. i switched them around, reset ecu, no cel. then i put wheels on, bolted exhaust up, welded shift linkages, made custom throttle cable bracket and took it for a spin. it waas vtec-licious LOL. thanks for the help guys!!
jdmvtecej2
Sep 17, 2008 07:31 AM
sc95delsol
Nov 13, 2007 05:08 PM
t3gb0y420
Jul 2, 2005 01:16 AM
SivikHatch
Jun 29, 2004 04:18 AM
T_Rex
27
Feb 12, 2003 07:41 PM
