replaced cap and rotor-now car won't start
Old May 7, 2005 | 02:02 PM
blackimaje2's Avatar
Default replaced cap and rotor-now car won't start
what's the deal with this?can a coil "just go out" for no apparent reason?anbody had a similar problem?help!
Old May 7, 2005 | 02:04 PM
vtec.dc2's Avatar
Default Re: replaced cap and rotor-now car won't start (blackimaje2)
did you reconnect the wires in same order?
Old May 7, 2005 | 02:19 PM
Default Re: replaced cap and rotor-now car won't start (vtec.dc2)
screwed on new rotorand replaced cap plug wires one at a time
Old May 7, 2005 | 02:22 PM
vtec.dc2's Avatar
whats the part number for both parts?
i had to replace mine recently and heres how it goes:
cap: 301-p72-006
rotor: 30103-p73-003
what happens when you turn ignition key to start?
Old May 7, 2005 | 02:35 PM
cap# is jh185 and rotor#is jr 165-and just to make sure i double checked my fireing order
Old May 7, 2005 | 02:38 PM
vtec.dc2's Avatar
the numbers i got are honda oem, what brand are these?
Old May 7, 2005 | 02:42 PM
the brand name is STANARD
Old May 7, 2005 | 02:54 PM
vtec.dc2's Avatar
hmm... is this for itr or for 90-91 integra? looking through their website this matches to 91 integra.. however, in your other thread you mention on having problem broken screw on distributor, is this before or after the problem? and i don't know if using magnet is the best thing around that area as someone replied to you.
Old May 7, 2005 | 03:55 PM
ringgold's Avatar
Right before Christmas I replaced the cap and rotor on my engine and as soon as I started the car up it idled for about 3 seconds and died. Turns out after some troubleshooting my coil bit the dust on me. It could very possibly be your coil. Follow the troubleshooting procedures in your repair manual and see if your coil is reading the right ohms on a mulitmeter. Thats how I found my problem.
Old May 7, 2005 | 07:37 PM
stumpyf4's Avatar
Did you crank the motor with the cap off to align the screw for the rotor? If you did you probably fried the something in the distributor.
You should pull the plugs and turn the motor over by had using the crank pulley.
Old May 9, 2005 | 04:38 PM
01usjdmr's Avatar
Did you check for the little spring in the top of the coil?
fortyfacemohwhat
Oct 17, 2008 05:40 PM
Chrisbequick
Oct 16, 2008 07:39 PM
mattymatt
Feb 23, 2004 04:57 AM
hoysum_dimsum
Feb 15, 2003 05:39 PM
junglistgsr
Dec 3, 2001 08:19 PM
