Squeaking Clutch... Anyone else have this problem?
Old May 6, 2005 | 10:11 PM
CHiNkStEr's Avatar
Default Squeaking Clutch... Anyone else have this problem?
While I was driving today I heard my clutch squeaking when I stepped on it. I was just wondering what I should use to make it not squeaky anymore. I was thinking WD-40 or some machine oil but I don't know where to spray yet. If anyone else had this problem let me know how you fixed and delt with it
Old May 6, 2005 | 11:59 PM
stripes777's Avatar
ive had this prob for years now, i just accept it as one of the normal things, haha. if u find out a solution let me know, ive changed master and slave clutch cylinders, it didnt help with the squeeking.
its only sometimes too, not always
Old May 7, 2005 | 12:11 AM
hatch34's Avatar
Default Re: (stripes777)
i had this prob too, i took a little wheel bearing grease and put it on the shaft coming from the fire wall to the pedal itself and used a little WD40 on the spring worked great for me
Old May 7, 2005 | 12:13 AM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 &raquo;</TD></TR><TR><TD CLASS="quote">ive had this prob for years now, i just accept it as one of the normal things, haha. if u find out a solution let me know, ive changed master and slave clutch cylinders, it didnt help with the squeeking.
its only sometimes too, not always</TD></TR></TABLE>
Change the springs in the clutch pedal. I think there is two. Then take never-seeze and coat the springs and the rod that pushes the clutch master cylinder. There is a black rubber boot around the rod. I just sprayed the rod and boot with never-seeze too. After all this it has never squeeked again .
B18C5-EH2
21
Nov 12, 2007 04:09 AM
redDAinteg
Mar 17, 2006 11:21 AM
tweekerz
Jul 11, 2005 01:28 PM
jdmeg9
Dec 20, 2004 05:10 PM
