gsr brake swap problem...version#2
Old May 6, 2005 | 09:41 PM
Leb_CRX's Avatar
Default gsr brake swap problem...version#2
since I didn't properly explain it, and the thread went to ***** let me try again
I have a 97 civic hatchback with a d16y7 engine. I am not swapping engines. I went to put GSR brakes from a 2000-GSR, auto I believe, and the axle's from my y7 do not appear to fit in the hub...is there anything I need to do? will they work with D series axles ok? if so which ones? the ones I have will not fit, I've tried everything, must be the teeth count
any help appreciated
Old May 6, 2005 | 09:56 PM
EL Vap133's Avatar
Default Re: gsr brake swap problem...version#2 (Leb_CRX)
Hmm, that's odd. I went with 99-00 Si brakes on my 97 dx civic and the d-series axles worked fine.
Old May 9, 2005 | 06:54 PM
gotboostedvr6's Avatar
Default Re: gsr brake swap problem...version#2 (EL Vap133)
the hub splines are the same should fit perfect.....
Old May 10, 2005 | 12:10 PM
Leb_CRX's Avatar
Default Re: gsr brake swap problem...version#2 (gotboostedvr6)
werd
https://honda-tech.com/zerothread?id=1237890
gnxpro24
Dec 17, 2010 10:26 AM
builthatch
May 19, 2007 02:42 PM
helpmeplease
Aug 30, 2005 11:33 AM
Leb_CRX
24
May 11, 2005 10:16 PM
Mach69
Feb 18, 2004 10:16 PM
