does anyone know how to use a obd1 dizzy on a obd0 car? SEARCHED.
i searched. i rewired it but it still didnt work...archives said someem about gear tooth differences but im just tryin to make sure if it does or doesnt work. if not ill just get a obd0...hey how about a b16 vtec obd0 dizzy...will that work...prolly...lmk
IT will not work unless you use an OBD1 ecu. To do that, you will need an OBD0-1 conversion harness as well.
you cany use a obd1 dizzy on a obd0 ecu. the obd0 have 16 tooth and the obd1 and up dizzy have 24 tooth. if you going to use a obd1 dizzy you need a to use a obd1 ecu
Modified by 2000civicsi at 10:15 PM 5/7/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi »</TD></TR><TR><TD CLASS="quote">you can use a obd1 dizzy on a obd0 ecu.</TD></TR></TABLE>
I'll assume you meant "can't".
how cany....ummm how bout obd0 vtec one.
i got another rewired obd1 dizzy and tried it again and it will only stay on for a split second so i guess it wont...have u guys atleast even tried before even if u think it wouldnt?
ludesrv
May 12, 2007 08:58 PM
EFing8
Jan 29, 2003 08:40 AM
