What tire size should I put in my konig heliums
Old May 6, 2005 | 08:17 PM
remymar's Avatar
Default What tire size should I put in my konig heliums
I have 15x6.5 konig helium and I want to know if I can put 205/50/15 without any problems. Wheel works recommends 195/50/15 but I want it to be a little bit wider for drag racing. thanks in advance.
Old May 6, 2005 | 08:22 PM
eda6's Avatar
Default Re: What tire size should I put in my konig heliums (remymar)
I have 205/50/15's on a 6.5" rim w/o issues.
Old May 6, 2005 | 10:18 PM
FlatlineEF9's Avatar
Default Re: What tire size should I put in my konig heliums (eda6)
it really depends on the rim, im running 205/50/15's but im on a 15X7. If i could do it over again, id probably go with the 195's, im turning into a fan of the stretched tires afterall. just my thoughts
Old May 6, 2005 | 10:40 PM
FalkenSiR's Avatar
Default Re: What tire size should I put in my konig heliums (FlatlineEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatlineEF9 &raquo;</TD></TR><TR><TD CLASS="quote">it really depends on the rim, im running 205/50/15's but im on a 15X7. If i could do it over again, id probably go with the 195's, im turning into a fan of the stretched tires afterall. just my thoughts</TD></TR></TABLE>
I already am. Streched tires have a lower diameter. A 195 will be lower than a 205 and so on...
Old May 7, 2005 | 05:22 AM
y49crxsi's Avatar
Default Re: What tire size should I put in my konig heliums (fast88std)
I am running 205 50 15 on 15x6.5 with no problem. There azenis too, so the actual tire is about 8 inches wide. There big. im not lowered though, so i dont have any issues with rubbing.
Old May 7, 2005 | 06:50 AM
fireant's Avatar
Default Re: What tire size should I put in my konig heliums (y49crxsi)
I've gone for more than 2 years daily driving and autocrossing with 205/50/15s on 16x6.5 heliums. It fits without an issue.
Old May 7, 2005 | 08:23 PM
remymar's Avatar
thanks guys, will put on 205's
Old May 7, 2005 | 08:58 PM
93formula's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
I already am. Streched tires have a lower diameter. A 195 will be lower than a 205 and so on...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatlineEF9 &raquo;</TD></TR><TR><TD CLASS="quote">it really depends on the rim, im running 205/50/15's but im on a 15X7. If i could do it over again, id probably go with the 195's, im turning into a fan of the stretched tires afterall. just my thoughts</TD></TR></TABLE>
what is this stretched tires???
Old May 7, 2005 | 11:51 PM
CRXDrew's Avatar
when the tire walls kinda / \ on the wheel. Atleast thats what the drift guys to. They think its pretty cool. 205 Azenis on my slip. 205&gt;195. Makes the rim look deeper and has better grip.
Old May 8, 2005 | 08:55 AM
93formula's Avatar
Default Re: (CRXDrew)
really so the smaller tire gives you better grip? si that for straight line? how bout for handling?
Old May 10, 2005 | 04:34 PM
Default Re: What tire size should I put in my konig heliums (93formula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">
what is this stretched tires???</TD></TR></TABLE>
muahahaha..... its funny you should ask.
my roommates 240
17X10" 5-zigens with 215/40/17. little bit stretched.
Old May 10, 2005 | 04:40 PM
93formula's Avatar
????? why would one do that????
any performance gains at all or is this just for looks?
Old May 10, 2005 | 04:43 PM
when youre drifting, (which he does almost everyday) if you have a large sidewall the car can be unpredictable with the tireflex. When the sidewall is already stretched the car breaks traction easier, and is more predictable when sideways. plus it looks crazy. he can still grip turns and drag too, ran 14.2 with full interior and sounds, spinning tire through 3rd gear.
Old May 10, 2005 | 04:48 PM
93formula's Avatar
interesting......
Old May 10, 2005 | 05:38 PM
CRXDrew's Avatar
What he said^^. Its all about drifto ****. My friend who is a Nissan Anti-ricer to the extreme hates people who have entered the Nissan world due to drifting. He said all the drift wannabes are doing the stretched tire thing now.
Old May 10, 2005 | 06:50 PM
88 rex's Avatar
I have 195's on my heliums but would like a 205.
Old May 10, 2005 | 07:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">What he said^^. Its all about drifto ****. My friend who is a Nissan Anti-ricer to the extreme hates people who have entered the Nissan world due to drifting. He said all the drift wannabes are doing the stretched tire thing now. </TD></TR></TABLE>
yeah, he has been drifting since 99. pretty good too.
Old May 11, 2005 | 11:11 AM
1bar_ek's Avatar
i have the 205/50/15's on my 15x6.5" heliums and they're fine. It won't be a problem.
lickety_britches
Sep 11, 2007 07:58 AM
CardDealer
15
Oct 6, 2005 03:51 AM
808State
Jan 30, 2005 12:48 AM
jimmhatch
12
Nov 21, 2004 01:41 AM
combustion
Nov 6, 2003 07:21 AM
