gsr brake swap...front knuckle problem
Old May 6, 2005 | 08:03 PM
Leb_CRX's Avatar
Default gsr brake swap...front knuckle problem
I am doing a GSR brake swap on my 97 civic h/b, using brakes off a 2000 GSR I believe...the rear's fit fine, but the front's, I cannot get the axle to go in...axle fits fine in the old one, but it seems to have a differant # of teeth?!? thats what it feels like to me, I have a D series in my civic, a y7...and cannot get them in for the life of me
is there something I need to do? will it not work with my D?
Old May 6, 2005 | 08:06 PM
e jay one's Avatar
Default Re: gsr brake swap...front knuckle problem (Leb_CRX)
hmm not sure did you count the teeth?
Old May 6, 2005 | 08:09 PM
Leb_CRX's Avatar
Default Re: gsr brake swap...front knuckle problem (e jay one)
nope, but that must be it, I thought I was doing something wrong, but I swapped knuckles again and my old ones, the axles just slipped in like nothing
I even tried cleaning it with wd-40 and a brush, to get any dirt out...and nothing...I've tried kicking it...hard, several times, it gets to where the 'tip' is barely pokign and refuses to go more, it has to be it
Old May 6, 2005 | 08:10 PM
e jay one's Avatar
yea i bet it is count em and tell us
Old May 6, 2005 | 08:14 PM
Leb_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">yea i bet it is count em and tell us </TD></TR></TABLE>
I will in the AM, any other ideas? do they have to be B series axles maybe?
Old May 6, 2005 | 08:16 PM
Bull_head360's Avatar
b series axles wont fit in d series tranny numb nuts
Old May 6, 2005 | 08:23 PM
Leb_CRX's Avatar
Default Re: (Bull_head360)
I know, I mean in the sense that I need a B series motor, public hair sun chips pepsi bottle idiot
Old May 6, 2005 | 08:25 PM
e jay one's Avatar
Default Re: (Leb_CRX)
hahaha yea get a motor swap just so your new brakes will work. haha
WildPig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bull_head360 &raquo;</TD></TR><TR><TD CLASS="quote">b series axles wont fit in d series tranny numb nuts</TD></TR></TABLE>
Wait, are you trying to fit the gsr knuckles onto the y7 axles? Or are you trying to fit gsr axles into a y7 tranny?
I thought you were talking about swapping out your old knuckles for the new gsr ones for the brake upgrade.......... if you are, then ^^^^^ this guy is a no talent *** clown.
PS: Gsr knuckles should fit d-series axles, never heard of anyone having a problem with that.
Old May 6, 2005 | 08:29 PM
Leb_CRX's Avatar
Default Re: (WildPig)
are the auto axles diff then the 5speeds? cause I think these brakes came off an auto GSR
nono I am trying to fit GSR brakes on my 97 civic H/B with a d16y7 engine, I am just saying is it impossible...and do they need a B series...not saing I am gonna get one, just wondering
Leb_CRX's Avatar
Default Re: (e jay one)
no man I am just saying...would I need a B series motor
Old May 6, 2005 | 09:29 PM
BadRelge45's Avatar
b series axles fit in your gsr rotors and don't fit into your single cam trans. So your gonna have to get a nice gsr swap to go with your new front brakes. sorry.
Old May 6, 2005 | 09:58 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (BadRelge45)
VERIFIED. Your axle may be nicked or stuck, but the Integra axle end and civic Axle end are the same. MEANING, if you put a Integra HUB on a civic knuckle, or both the integra hub/bearing/knuckle on a civic, the axle WILL fit. so.....force it?
https://honda-tech.com/zerothread?id=1049174
Old May 7, 2005 | 05:21 PM
Leb_CRX's Avatar
Default Re: (Redline96LX)
I can't get it on, and I've tried REAL hard
gonna swap hubs on monday, and hopefully that does the trick
Old May 7, 2005 | 05:40 PM
Status Sean's Avatar
your hub must be messed up because a friend way back in the day had 5 lug on his hatch and he stil had a sohc and it worked ! i dunno what to tell ya man !
Old May 7, 2005 | 05:48 PM
pdiggitydogg's Avatar
Integra (minus itr) knuckle's hubs are the same as civics.
Check your integra hubs for damaged splines if your axle's splines are ok.
Old May 8, 2005 | 11:07 AM
Leb_CRX's Avatar
Default Re: (pdiggitydogg)
they are ok, I am sure of it...both sides don't fit...they are not the same size
I am gonna swap hubs on monday
Old May 8, 2005 | 11:20 AM
JDM SLICK's Avatar
yeah what he said...
Old May 8, 2005 | 10:32 PM
let us know if it was the hubs if you get it figured out
Old May 9, 2005 | 04:40 PM
Leb_CRX's Avatar
here's what I ended up doing
I examined them both and htey look identical, so I scrathced my head some more and tried to figure it out...well
I had a spare d axle hanging around, I ripped it apart and tried to get it to fit...it would go a bit, but not much...so I actaully had to hammer it inside the knuckle...and oddly enough it worked..hammered the fawk out of it...then hammered it out, did that a few times, it got stretched good enough for me to fit my big greased up axle inside
so maral of the story...sometimes, it's good to hammer the living **** out of ****
Old May 9, 2005 | 06:16 PM
* B A N N E D *
second.
Old May 11, 2005 | 04:40 PM
lol, you had to grease up your big rod so that it would fit in the tiny hole...sounds like what i did to my ex...
Old May 11, 2005 | 09:51 PM
Leb_CRX's Avatar
werd
sounds like what I did to your ex too
Old May 11, 2005 | 10:06 PM
allmotorEG-SI's Avatar
damn is that why that **** was all tore up when i got to it. Thanks a lot guys. :?
Old May 11, 2005 | 10:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (allmotorEG-SI)
jdp1978
Nov 14, 2009 07:51 PM
JLEK
May 28, 2007 01:32 AM
Steve_civicGSR
Oct 4, 2005 08:42 AM
Leb_CRX
May 10, 2005 12:10 PM
