NEED GOOD HELP MY CAR IS OVERHEATING THIS IS NOT A DUMB QUESTION
Old May 6, 2005 | 12:55 PM
boostng r's Avatar
a
Default NEED GOOD HELP MY CAR IS OVERHEATING THIS IS NOT A DUMB QUESTION
my gauge goes up while i am sitting at a stop sign or when it is idleing so i change the radiator ,waterpump,thremostat,all 3 coolent sensors fan works all the hoses there is no leaks when it over heates it pushes coolent in the over flow the gauge works
everything is new and oem honda parts i cant fuken understand this ****
i did a leak down test its 1 percent on al lfour cylinders
Old May 6, 2005 | 01:00 PM
Cboy1-EG6's Avatar
Default Re: NEED GOOD HELP MY CAR IS OVERHEATING THIS IS NOT A DUMB QUESTION (b16coupe4)
Hmm... If you replaced everything you should be fine... Can't understand it either but bumps to a guy in need of help...
Old May 6, 2005 | 01:34 PM
donut.'s Avatar
Default Re: NEED GOOD HELP MY CAR IS OVERHEATING THIS IS NOT A DUMB QUESTION (Cboy1-EG6)
you might have air in your coolant system. try bleeding the air, and if that doesn't work, flush out all the coolant and refill it
Old May 6, 2005 | 03:00 PM
Morning Call's Avatar
exactly what donut says
u might have a air bubble in ur coolant
Old May 6, 2005 | 03:11 PM
BadRelge45's Avatar
is the coolant circualating? if not hook a garden hose up to it.
Old May 6, 2005 | 03:12 PM
EJ1 wilcox's Avatar
Default Re: (BadRelge45)
Blown head gasket?
Old May 6, 2005 | 03:33 PM
Yoshiod9's Avatar
From: vacaville for holiday, sacto for school, ca, united states
you've probably done this, but in case you forgot the simple things...remember to check your fuses and relays. other than that, i'm at a loss.
Old May 6, 2005 | 03:41 PM
BadRelge45's Avatar
i mean hondas don't even need a cooling fan. mine is wired to a switch on my dash and i never have to flip it on. the only time that mine got hot was when i drove it for 2 hours straight and let it idle for 20 min. then i put the fan on and it cooled right down. i think something is restricting the coolant flow whether its some **** or air
Old May 6, 2005 | 10:34 PM
Yoshiod9's Avatar
bad- uhhh...yeah they do. i don't even have an engine that i thought would get that hot but i've been overheating as well. it's a y7 and ANY time i'm stopped and idling for more than 2 minutes, the temp gauge goes sky high. as long as i'm driving, i'm ok, but if i'm sitting somewhere with the engine on, it'll overheat.
Old May 7, 2005 | 10:12 AM
jbscivichb92's Avatar
Default Re: (Yoshiod9)
its gotta be some kind of blockage in your coolant system. drain your coolant, pull the hose off of your radiator and spray a garden hose into the hose with the engine running. that should clear it out. i think the make chemicals for cleaning out your coolant system.
Old May 7, 2005 | 11:38 AM
boostng r's Avatar
a
yeah i people says its the headgasket there is no air in the system wat so ever when it starts to get hot the overflow gets full i am sick of this problem i think maybe it s my head gasket
i am also running a 2 layer headgasket since i am allmotor and 13 flat compression i dont if that helps
Old May 7, 2005 | 11:46 AM
dorikingts's Avatar
pull our thermostat out, and boil a pot of water, and see it it poips open. your thermostat might be out, its only like a 5 dollar peice, and you can run your car without a thermostat during the summer, it will help[ it run cooler, remember to put it back in for winter because if you dont, you wont hav heat.
Old May 7, 2005 | 11:49 AM
DBLAZE's Avatar
Default Re: (dorikingts)
I am almost certain that this is a head gasket issue!!! Just my 2 cents!!!
Old May 7, 2005 | 12:07 PM
boostng r's Avatar
a
its a brand new thermstat from hodn aman i dont wanan run with out one if i have a other problem i ould liek to fix it so it runs like a normal car ya know
i thk its a headgasket
Old May 7, 2005 | 12:14 PM
Kamin's Avatar
Default Re: (b16coupe4)
you guys skipped a huge one
is the fan turning on?
while the car is warm, start it somewhere quiet (like a garage) and let it idle, watch the temp. if it starts to overheat without the fan turning on it could be something like a relay or fuse.
Old May 7, 2005 | 12:15 PM
Status Sean's Avatar
theres a little nipple on the motor above the top radiator hose ! bleed that to make sure theres no air in it ! if it aint that i dunno son !
Old May 7, 2005 | 12:34 PM
boostng r's Avatar
a
ok for the fan the fan is on all the time to keep it cool i got it jumped and the system has no air in it and there is no nipple on my head for letting the air out but i know what u arre talking about
Old May 7, 2005 | 10:19 PM
boostng r's Avatar
a
ok i changed my headgasket so far it s not overheating i just drove it for liek 2 miles and back home ready to go out with the lady i will keep u guys posted
Old May 8, 2005 | 11:48 AM
boostng r's Avatar
a
welll it ways the gasketguys thanks for every body helping me
panchlow
May 2, 2011 05:06 PM
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
nonhondaman
Apr 17, 2007 07:26 PM
simplypinoyy
23
Aug 6, 2004 03:06 PM
CW-ITR-329
Jul 20, 2002 03:50 PM
