Catalyst system efficiency below threshold
I got OBD code: Catalyst system efficiency below threshold.
Is this my O2 sensor or is it the cat?
It's a 96 civic lx.
Help?
ps: search engine is down.
It's a 96 civic lx.
Help?
you have a bad cat. if you have a code scanner wiith readings. You should be able to see if you o2 is switching. But I think you have a bad cat. Just shake it or hit it with your hand (when cold.) If its good you should not hear anything, and if its bad you will hear it rattle.
Depends...I dont know your mods. Sometimes with an aftermarket highflow cat cars will throw that code because the cat isnt getting hot enough or some rediculous thing. I would first try to replace the 02 sensor, if that doesnt work then go for the cat. You may have just fouled the sensor.
kieranmullen
23
Sep 25, 2008 08:45 PM
1SloNeon
11
Jul 5, 2008 09:45 AM
