FS: 2 ZCVtec engines so-cal
Old May 5, 2005 | 05:36 PM
bluebird's Avatar
Default FS: 2 ZCVtec engines so-cal
Up for grabs are two ZCVTEC sohc vtec engines. These are JDM 1.6L sohc vtec. .... Arguably the best of the sohc family....$450
140HP
Modified by bluebird at 5:52 PM 5/6/2005
Old May 5, 2005 | 09:47 PM
bluebird's Avatar
Default Re: FS: 2 ZCVtec engines so-cal (bluebird)
ttt
Old May 6, 2005 | 10:38 AM
bluebird's Avatar
bump
Old May 6, 2005 | 10:40 AM
Skank_aSS_Dara's Avatar
any pictures how is this a ZCVtec?
Old May 6, 2005 | 10:41 AM
bluebird's Avatar
Default Re: FS: 2 ZCVtec engines so-cal (Skank_aSS_Dara)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skank_aSS_Dara &raquo;</TD></TR><TR><TD CLASS="quote">any pictures how is this a ZCVtec?</TD></TR></TABLE>
I can get you pics tomorrow in the a.m.. ZCvtec are JDM motors 1.6 sohc vtec... Block are stamped ZC not D...And no these are not hybrids.. that is how they came in japan!!!
Old May 6, 2005 | 12:57 PM
bluebird's Avatar
To the top please
Old May 6, 2005 | 02:58 PM
bluebird's Avatar
up again
Old May 6, 2005 | 04:53 PM
bluebird's Avatar
140 Raw sohc horsepower
Old May 6, 2005 | 04:56 PM
allmotorEG-SI's Avatar
Sorry pal, thats DOHC zc your thinking of. The SOHC zc has 130 and is exactly identicle to us d16z6 expecpt for a missing smog peice on the intake manifold which i attribute to the extra boost in 5hp. the NON-VTEC zc is the one with 140, but your not selling that.
Old May 6, 2005 | 07:09 PM
tealjdmcrx's Avatar
Default Re: (allmotorEG-SI)
actually ZC dohc only has 137 ZCvtec has 140
http://www.sunrisejdmmotors.com/honda.php
Old May 6, 2005 | 07:17 PM
i belive there numbers are incorrect. 17hp over usdm and really not change at all in the engine except for some smog equipment, i don't think so. They're numbers are inflated.
Old May 7, 2005 | 09:44 AM
bluebird's Avatar
If you look at the specs closer you would see a jump in compression!!! Do a search my friend...ZCvtec is sweet!!
Old May 7, 2005 | 12:07 PM
bluebird's Avatar
Default Re: (bluebird)
bump
Old May 7, 2005 | 05:11 PM
bluebird's Avatar
mmmmmmmmmmmmm zcvtec
Old May 7, 2005 | 05:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird &raquo;</TD></TR><TR><TD CLASS="quote">If you look at the specs closer you would see a jump in compression!!! Do a search my friend...ZCvtec is sweet!!</TD></TR></TABLE>
no compression should be the same, pistons same, engine same.
Old May 7, 2005 | 06:35 PM
bluebird's Avatar
Up for the non haters!!!!
Old May 7, 2005 | 07:22 PM
SOHCEK-Turbo's Avatar
MMMhh ?
ZC Vtec I knew that engine existed. Had a little argument a few weeks ago about it on the EG or EF forums. I had no proof though. I think your HP numbers are a bit inflated and the engine is 130bhp while the DOHC ZC is 128bhp. The ZC SOHC Vtec is the best of the D series. I wouldnt be surprised if it is over 130bhp though. Since it might have pm6 pistons in it and that bumps up the CR.
Old May 7, 2005 | 07:31 PM
bluebird's Avatar
Default Re: (EK-TSOHCV-TechRider)
I have personally driven a hatch with a zcvtec after he swapped out the y8 and it was a noticable difference!!!! It is boosted now so it is a huge difference!!!
Old May 8, 2005 | 07:50 AM
well of course it is noticeable the y8 is as powerful as the z6. when i got my zc it drove almost the same as my z6, very little improvement at all. But it was kinda hard to compare the 2 engines. THe z6 was really old and probably not making stock hp numbers anymore. The zc was just more responsive, that was all.
Old May 8, 2005 | 08:38 AM
bluebird's Avatar
The Y8 was low mileage!!! He swapped it and is loving it!!!! The twincam ZC sucks!!!
Old May 8, 2005 | 10:51 AM
ha, yeah DOHC zc is gay, i agree with you on that one.
Old May 8, 2005 | 09:51 PM
bluebird's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorEG-SI &raquo;</TD></TR><TR><TD CLASS="quote">ha, yeah DOHC zc is gay, i agree with you on that one. </TD></TR></TABLE>
Very!!!!
Old May 9, 2005 | 03:40 PM
bluebird's Avatar
The best sohc!!!
Old May 10, 2005 | 04:46 PM
bluebird's Avatar
one down....One left!!!
Timmay
43
Mar 12, 2007 10:16 AM
SoullessJapaneseMachine
27
Dec 4, 2006 06:46 PM
turbow
31
Feb 25, 2005 10:13 PM
bspeed
25
May 22, 2004 06:25 PM
