putting b16a in hatch
im going to be purchasing a hatch very soon and doing a swap i was thinkin about doing a b16a w/ lsd trans...is this a good swap to do..and what can i expect from doing this swap?
Im thinking that someone is going to put a link to the search feature as a reply.
Then someones gonna give you a link to the stick of "what swaps should i do to my civic"
but im gonna straight up call you retarded because this happens every week and every time someone like you takes up the forum space getting flamed cause you were too stupid to search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetEG »</TD></TR><TR><TD CLASS="quote">Im thinking that someone is going to put a link to the search feature as a reply.
gotya on this one
</TD></TR></TABLE>gotya on this one
b16a is a good building ground for a turbo. You might want to re-think the itr tranny though if your going fi, it's too short of a gear ratio meaning you'll have traction problems and turbo lag (depending on turbo size) however this is all debatable. If your going n/a your good to go.
b16b has more hp because of higher compression and superior cams and valve train but imo if your going n/a it still lacks the torque you'll get out of a b18b/c/c5. I also feel that it has too high of a comp. rato to go with FI.
nefariousyellow
Sep 13, 2007 10:15 AM
