How Can I swap engines between a GSR & a B16a Hatch?
What to I need to swap engines between a GSR & a B16a Hatch?
How do I go about swapping the engines between my 00 GSR and my B16a Hatch? Can I use the same mounts currently used in my Hatchback for the B18c1? Can I use the ECu from the GSR in the Hatch? How about for the GSR? It'll be going from an OBD II b to an OBD I? Any help? Thanks. Any other things I'm missing?
Re: (nefariousyellow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nefariousyellow »</TD></TR><TR><TD CLASS="quote">That Helps! I've been doing that, and posted this to get current feedback. Not that you have anything to say about it.</TD></TR></TABLE>
ok bro. what year is your hatch anyways? you can use the same mounts from the motor if its the between the years 1992-2001. (1992-1995) is OBD1. (1996-1998) is OBD2a and (1999-2001) is OBD2b. <i.(*correct me if im wrong about the years*) [/i]So if your going to swap ECUs out from car to car, your going to need a ECU jumper harness.
Re: (b16a3delsol)
I have searched, and just keep getting mixed answers... I think this is all I need ;
ECU harnesses, to make my 94 hatch an obd II(b) and another one to make my Integra an obd I. As far as the ECu's can I still use the ones I have running in each for the swap? And how about the mounts, can I still use the stock GSR ones to put in the b16 in it and the mounts in my hatch to recieve the b18?
nefariousyellow
09-14-2007 12:33 PM
MUGEN_B16CIVIC
21
04-18-2004 06:58 PM
