B18C swap P.S. questions?!?!?!?....HELP
I think I'm having the worst luck for a first time swap. I have the B18C in my car (EK). I only have a few more things to connect. I'm curious to know if i can reuse my SOHC power steering pump to be able to reuse my P.S line. Is this possible? If not, I've noticed by looking at pics of the 94 integra P.S line that the end of the line is completely different from the Civic's. How am I supposed to make this work? Please someone help me out...I'm a NOOB. Also what will i need to connect the clutch line to my SOHC line. The line off the B18C has been cut after the rubber hose.
You gotta try to use your old pump. If it doesn't bolt up goto Homedepot and get some long bolts and a bunch of washers as spacers.
I can also tell you that the PS pump that came on my 99 b18c1 (US) fit fine with the hose in my 96 EX.
in order to make the GSR PS work on your EK you will have to slightly bend your PS hose to clear the valve cover.
but like Phatcivic213 said the hose will fit, just match up the bolt holes and see how much you will have to bend the ps line.
As far as your clutch line, you might wanna hit up your local junk yard.
fordmike1980
May 27, 2018 08:53 PM
