quick question about Golden Eagle oil filter sandwich plate
Old May 5, 2005 | 12:06 AM
BlueShadow's Avatar
Default quick question about Golden Eagle oil filter sandwich plate
Hi Guys,
I'm gonna swap out my Greddy plate for the GE sandwich plate, but I had a quick question. I want to use the GE 1/8 NPT port for my oil pressure and temp gauge. Then the larger port for the feed line. I wanted to check on which fitting I need to for the large port to work with my 3 AN line.
I'm guessing that it is the 3/4" boss to 1/8 NPT, but I wanted to be sure before I order it.
http://www.robearracing.com/pd...n.cfm
EDIT: also I have some spare male 1/8 NPT to male 3 AN fittings. I should be able to screw one of those into the 3/4" boss to 1/8 NPT adapter and run my 3 AN line off of that right?
Thanks
Old May 5, 2005 | 02:07 AM
BlueShadow's Avatar
Default Re: quick question about Golden Eagle oil filter sandwich plate (BlueShadow)
n/m I did some searching in the archives and saw a post by "GoldeneagleMFG" and it had a pic of the adapter. It looks like the adapter needed is the 3/4 boss to 1/8 NPT, so that's what I got.
http://www.goldeneaglemfg.com/...F8NPT
Old May 5, 2005 | 04:07 AM
acurar0ss's Avatar
my ge adaptor came with that adaptor....... no need to buy it seperatly
Old May 5, 2005 | 05:14 AM
IN VTEC's Avatar
-8AN o-ring port to -3AN flare adapter or some combination that gets you there.
Altho, I just realized that you might be able to use a -8AN flare to -3AN flare male union because there's a flare on the GE plate. It's much easier to find a falre to flare reducer than an o-ring port to flare reducer. I'm just not sure if it's appropriate to use it. I've had an oil leak before when I used a -8AN flare plug on it, but I'm not sure that's where the leak was...might not have been on the plate at all.
Old May 5, 2005 | 05:22 AM
BlueShadow's Avatar
Default Re: quick question about Golden Eagle oil filter sandwich plate (IN VTEC)
Well I have a few spare male 1/8 NPT to male 3 AN fittings, so I figured I'd get the 3/4" boss to 1/8" NPT adapter. I already bought it so it's to late to go back. If the parts get here and it's the wrong one, I'll just order the right one from GEmfg.
civicSIhatch93
Apr 26, 2013 10:42 PM
boostedteg909
Aug 15, 2011 11:57 PM
DukeCityEF
Jan 11, 2008 12:21 PM
egreenmachine
May 6, 2007 09:30 PM
Da1spaz247
Apr 26, 2006 12:43 PM
