where to buy adjustable water pump<<<<
Old May 4, 2005 | 08:33 PM
lemongreenhatch's Avatar
Default where to buy adjustable water pump<<<<
ok i have a deckplate b-series motor and lookin for an adjustable water pump i heard Ge makes 1 but they stopped any help or if any1 has a used 1
Old May 4, 2005 | 09:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: where to buy adjustable water pump<<<< (poorman's-allmotor)
What is the purpose of an adjustable water pump? What are you trying to adjust?
Old May 5, 2005 | 07:14 AM
Default Re: where to buy adjustable water pump<<<< (Arturbo)
the purpose is to use a oem size belt cuz i have a raised deck block
Old May 5, 2005 | 07:33 AM
B20vtec86crx's Avatar
mmmm...how would adjustable water pump work? we used nissan t-belt in one of the deck plate motor ..you can cut up old t belts and tape them together and take it to napa to have them match it to the right length.
good luck
Old May 5, 2005 | 07:47 AM
Default Re: where to buy adjustable water pump<<<< (B20vtec86crx)
i dont know how it would work im guessing the the pulley on the water pump is adjustable giving it enough slack for the oem t-belt but i might try what ur talkin about and go to napa ,.... 1 guy said hes using a ford t-belt on his deck plate
Old May 5, 2005 | 08:47 AM
Muckman's Avatar
Moderator in Chief
How much is your deck raised? If its not major you may be able to use adjustable cam gears.
Tash.v
Honda Civic (2001 - 2005)
Oct 25, 2018 02:32 PM
miketines
Aug 15, 2017 02:22 AM
Mr_Moos
Jun 24, 2007 10:04 PM
ismael-robert
Jun 15, 2006 11:32 AM
h22 civic
Oct 13, 2004 06:40 PM
