EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ?
Old May 4, 2005 | 08:21 PM
The DX Rex's Avatar
Default EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ?
will the rear disk off a 90-93 DA Integra work on my 93 hatch???
i know dc2 rear disk works but the reason i am asking is because the local junkyard usually has ton's of DAs and they had one 95 ls integra there, i pulled the rear disk conversion off for $70 bucks total for both sides but ended up trading it to my boy so i was wondering if i could use the DA rear disk.
thanks.
Old May 4, 2005 | 09:17 PM
Calvinator's Avatar
Default Re: EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ? (nyhustla2k)
yes it fits, im running DA rear discs on my eg. Im also using the e brake lines and the 90-93 RS prop valve, BB and MC
Old May 4, 2005 | 10:29 PM
The DX Rex's Avatar
Default Re: EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ? (xtremeazian)
nice nice thanks
Old May 4, 2005 | 11:27 PM
JDM SLICK's Avatar
yeah what he said...
Old May 4, 2005 | 11:38 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyhustla2k &raquo;</TD></TR><TR><TD CLASS="quote">nice nice thanks </TD></TR></TABLE>
no problem, it was an *** getting the MC and BB in because it barely fit, compared to the stock eg one. and I had to slightly bend the lines to fit the prop valve.
Old May 6, 2005 | 07:34 AM
slowturbocx's Avatar
i was wondering the samething
Old May 6, 2005 | 07:45 AM
Will_the_Thrill's Avatar
Default Re: EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ? (slowturbocx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM *** &raquo;</TD></TR><TR><TD CLASS="quote">yeah what he said...</TD></TR></TABLE> ...Post *****
what year teggy rear disc brakes fit on the eg....im thinking about buying a pair for $50, but there are no ebrake lines......time to visit local junkyard....whats the estimated time to install?
Old May 6, 2005 | 08:31 AM
pramonn's Avatar
Umm How about P.C.D.
Im not sure but it a good recheck cos some DC2 equiped with 4x114.1 pcd while EG is 4x100 pcd.
just want to help you recheck it fit for the plat form and also you nice old wheels.
Correct me if Im worng.
Old May 6, 2005 | 09:41 AM
Calvinator's Avatar
Default Re: EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ? (DSM2fastEG2clean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSM2fastEG2clean &raquo;</TD></TR><TR><TD CLASS="quote"> ...Post *****
what year teggy rear disc brakes fit on the eg....im thinking about buying a pair for $50, but there are no ebrake lines......time to visit local junkyard....whats the estimated time to install?</TD></TR></TABLE>
Any rear discs from 90-01 will fit your eg. It took me about 3 hours because I had problems with installing the prop valve. This includes bleeding the brakes too.
Old May 8, 2005 | 06:52 PM
turbosnatch's Avatar
will this also include working with a ek dx h.b?
Old May 11, 2005 | 12:36 PM
funkfnamna's Avatar
Default Re: (turbosnatch)
so if the DA's fit then EF's would to right. I'm junking my EF cause the shell is beat but I wanted to swap out the disks and engine into a EG.
Old May 11, 2005 | 12:38 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosnatch &raquo;</TD></TR><TR><TD CLASS="quote">will this also include working with a ek dx h.b?</TD></TR></TABLE>
Yes, along with coupes. I put a 92 integra rear disc on a 97 EX coupe.
Brock Brum
Oct 16, 2017 10:23 AM
88 EF Hatch
Mar 3, 2009 10:12 AM
88 EF Hatch
Mar 3, 2009 08:47 AM
Civiclized
Apr 21, 2005 04:13 AM
hqr180
Nov 23, 2004 12:42 PM
