lights flicking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz »</TD></TR><TR><TD CLASS="quote">It could possibly be a bad ground, belt slipping, bad connections, or the alternator is going out or you're pulling too much of a load for your alternator to keep up with.</TD></TR></TABLE>
got a system or aftermarket headunit?
I have an EH3 as well and I've found two different things that cause this and I'm suprised no one else has brought them up yet... A) The dimmer switch B) The headlight/turn signal switch. Mine was doing this and I first found that if I played with the dimmer switch it would work fine, I replaced that eventually with a junkyard one and it was all good and then the headlight/turn signal switch started acting funny. Now if I play with the headlight switch (kind of rock the switch between headlight and running light setting) it starts working again. Give it a shot, it's a more simple solution than some of the other alternatives for a starting point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">cant i go to auto and they can check it rite?</TD></TR></TABLE> Just pull um all one by one and see if there all good. there is only like 15 or sometin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">Check your alternator relay fuse in the fuse box under the dash. </TD></TR></TABLE> the black one?
slow_rex_will
May 21, 2005 01:04 PM
