Will a STOCK integra type R airbox fit a 99-00 civic?
Old Feb 2, 2002 | 10:27 PM
Tyson Ballou's Avatar
Default Will a STOCK integra type R airbox fit a 99-00 civic?
Will the Stock airbox off a integra type r fit a 99-00 civic? Any mods you have to do to make it fit.. i was told that the chambers are different then the Si one.. and would be a benefitial mod..? enlighten me
Old Feb 3, 2002 | 07:41 AM
AmauryR's Avatar
Default Re: Will a STOCK integra type R airbox fit a 99-00 civic? (MiGs)
I haven't seen the ITR airbox, but if its like the gsR airbox, then u can make it fit a 92-95 chassis - true, it sits a bit high, but there's clearance (not the greatest). You have to remove the "leg" that sits next to the radiator-hose (use a dremel, or hack it off), then bolt it down with the 1 mounting point that lines up (right on the side of the shock tower), and then you'll have to drill 1 hole for the "leg" infront of the box, it sits on that flat part behind the headlight. After that, get a clamp that bites tighter that the stock one (or try the stock civic clamp), after that, hook up any hoses and your str8. PS. yes there is a little difference (I have a '93 Si hatch)
Old Feb 16, 2002 | 05:04 AM
SpecR_EK's Avatar
New User
Default Re: Will a STOCK integra type R airbox fit a 99-00 civic? (JFK.com)
I'm pondering doing the same thing to my 6g civic. I hope the airbox fits.
Old Feb 16, 2002 | 07:55 AM
Cheap Bastard's Avatar
New User
Default Re: Will a STOCK integra type R airbox fit a 99-00 civic? (SpecR_EK)
Just buy a Comptech box. It not worth the effort, unless it's like 1/2 the price.
CB
Old Feb 16, 2002 | 03:19 PM
SpecR_EK's Avatar
New User
Default Re: Will a STOCK integra type R airbox fit a 99-00 civic? (Cheap Bastard)
It's less than 1/2 the price of a comptech airbox. I'm getting it used.
[Modified by SpecR_EK, 4:19 PM 2/16/2002]
Old Feb 16, 2002 | 06:10 PM
irev210's Avatar
CTR intake looks beefy to me, i wanna get that
Old Feb 16, 2002 | 07:04 PM
uc0083's Avatar
Default Re: Will a STOCK integra type R airbox fit a 99-00 civic? (sirhatchback)
It fits but not that well it has sme movement and I had to make a braket but it fits.
rubikscube
Sep 27, 2011 07:45 AM
blackccoupe
Audio / Security / Video
Sep 9, 2009 04:29 AM
