opinions on greddy blue box?
Old May 4, 2005 | 04:18 PM
Bimmerman's Avatar
Default opinions on greddy blue box?
I am thinking of running it for a couple months until I can get a stand alone and tune. We it be ok to run 8-10 psi?
or should I try and get a afc?
Old May 4, 2005 | 04:47 PM
CASH's Avatar
Default Re: opinions on greddy blue box? (Bimmerman)
i ran my d15b on the blue box for a couple months at 10 psi and it was fine. upgraded however to the e-manage. After doing some research i found out the box is designed to always keep the car running rich. IMO try to fabricate a kit close to the greddy kit if u plan to use the blue box, ie, tdo5, 310 cc injectors etc. since the box is preset to run a certain setup...
Old May 4, 2005 | 05:12 PM
Tetronious's Avatar
Dont risk the chance of messing up your motor. The blue box is made to run at what its set for (usually 5-6psi) its not going to compensate for your fuel or timing. Ive ran mine for about a year and half at stock boost. Yes it sucks and god its slow, but the motor is still running good
Tetronious
00 SI
Boosted
Old May 6, 2005 | 04:30 PM
Harassing Herbs's Avatar
Default Re: opinions on greddy blue box? (Tetronious)
the blue box is good to about 8-10psi. it will serve the purpose you looking to use it for.
if your on a budget look in to UBERDATA
a great stand alone u can tune yourself and costs about 500 for needed equipment & wideband
Modified by Harassing Herbs at 11:03 AM 5/8/2005
lDanny
Mar 30, 2005 02:14 PM
dynamicRacing719
Jan 17, 2005 06:15 PM
boostincoupe
May 20, 2003 03:29 PM
99ls
May 12, 2003 01:10 PM
turbod16y7vtec
Dec 12, 2002 08:48 AM
