What does this part do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK »</TD></TR><TR><TD CLASS="quote">since u aint in california ur fine, its only for the smoging purposes. You wont get any codes nor mess with the engine.</TD></TR></TABLE> That is why I am asking, I failed emissions in wisconsin. Think this is the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matrix_Zero »</TD></TR><TR><TD CLASS="quote"> That is why I am asking, I failed emissions in wisconsin. Think this is the problem?</TD></TR></TABLE>
probably
probably
i don't really thing that would cause u to fail, i know people that have removed the canaster all together and have passed MD emissions, how long has it been since u did a tune up , plugs wires, dizzy cap rotor,, how old is ur o2 sensor that can be a big problem if its old.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 »</TD></TR><TR><TD CLASS="quote">i don't really thing that would cause u to fail, i know people that have removed the canaster all together and have passed MD emissions, how long has it been since u did a tune up , plugs wires, dizzy cap rotor,, how old is ur o2 sensor that can be a big problem if its old.....</TD></TR></TABLE> o2 sensor is brand new, but it didn't seem to make much of a difference. How do I know if it is working... I tried t test voltage on either one and niether are sendinga ny signal. The book says it should be between .4 and .6 volts depending on WOT or Closed and RPM's. But I get nothing. How do you test the o2 sensor?
well if it wasn't working u'd probably have a CEL.. i see in ur sig that u have a 88 with a B16,, i belive most of the obd0 B16's have 2 o2 sensors, well depending on what ecu u use
