dohc zc into 90' civic dx
Old May 4, 2005 | 11:05 AM
baked_beanz's Avatar
Default dohc zc into 90' civic dx
what will i need?? besides wiring it to mpfi. ill need the motor& tranny. will i need mounts or shift linkage?? let me know thanks
Old May 4, 2005 | 11:10 AM
EP3_05's Avatar
Default Re: dohc zc into 90' civic dx (baked_beanz)
MPFI wiring and everything else should bolt right up. No mounts or linkage needed.
Old May 4, 2005 | 11:11 AM
are you positve?because i can get a z motor for like 100.00
Old May 4, 2005 | 11:13 AM
EP3_05's Avatar
Default Re: (baked_beanz)
Yes I had a zc in my dx 4dr and I used the stock mounts and linkage.
Old May 4, 2005 | 11:17 AM
ex voto's Avatar
Default Re: (91civic)
I just did the exact swap. The tranny bolts right up, used the same clutch and the linkage works. Well... not the exact swap. I had an EX that had the MPFI anyway.
Old May 4, 2005 | 12:51 PM
is it work all the work putting it in? i mean will i feel any power differances
Old May 4, 2005 | 12:56 PM
EP3_05's Avatar
92 flywheel hp --> 130 flywheel hp
You do the math
I was running low 17's with my dx 4dr and dropped all the way to 15.3@88 with the zc. Now with my b16a I run anywhere from 14.5-14.8 on a consistent basis.
Old May 4, 2005 | 01:47 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default Re: dohc zc into 90' civic dx (91civic)
DO IT DOHC ZC's KICK ***!
Old May 4, 2005 | 02:22 PM
Rex_Ryder's Avatar
Ya do it! It does kick ***. Here's a site that will answer most or all of your questions with the ZC swap.
http://www.dmoore.com/crx/zc.h...0Cost?
tkda
18
Feb 5, 2009 03:24 PM
the king.
Nov 25, 2006 12:56 PM
ZC_Vtec_Civic
Jul 29, 2004 08:56 PM
johnny hatchback
Mar 25, 2002 04:32 AM
Mattydevine
Feb 12, 2002 04:41 AM
