255 fuel pump not cutting it. T4 car....options?
Old May 4, 2005 | 10:28 AM
Turbo-charged's Avatar
Default 255 fuel pump not cutting it. T4 car....options?
car has a standard 255 pump in it at the moment and its making me real nervous. i have a relay running the pump with 10 gauge wire. regardless its time to step it up.
here are the pumps i have collecting dust.
Venom 650 horsepower pump i beleive it is. its used.
i also have a Aeromotive 1000 HP pump. things huge, big and heavy. whatever.
so i guess my real question is which route should i go with this? ive seen people run the venom pump in the engine bay after the fuel filter.....this doesnt seem right to me.
then with the aeromotive pumps i would obviously mount under the car with its own lines.....but whats the best way of getting the fuel from the tank to the pump. ive seen people just put a fitting in the drain hole, ive seen people weld an extra bung in the tank.....whats legal...whats ideal...and whats easiest that should work.
any sugestions greatly appreciated. just trying to do this fairly simple if possible. it would be awesome to not have to drop the tank..but im sure i'll have to.
Old May 4, 2005 | 10:51 AM
_entropy's Avatar
Default Re: 255 fuel pump not cutting it. T4 car....options? (Turbo-charged)
Add a second intank walbro. Tons of supras using that to 900+ RWHP.
Old May 4, 2005 | 11:50 AM
SpoolnG2's Avatar
Default Re: 255 fuel pump not cutting it. T4 car....options? (Napoleon Dynamite)
if you are gonna use the aeromotive, def. dont use the drain plug. Your gonna wanna buy a sump and have it welded in.
Modified by SpoolnG2 at 6:10 AM 5/5/2005
Old May 4, 2005 | 12:17 PM
Default Re: 255 fuel pump not cutting it. T4 car....options? (SpoolnG2)
nah walbro's going on the parts shelf. i already went ahead and pulled the tank out. i found a SX pump i forgot i had.....i think im going to use that. havnt decided how i want to deliver the fuel to the pump yet though.
Old May 4, 2005 | 04:04 PM
SFWD 1934's Avatar
Go with the A1000. Don't forget to put the 100 micron filter in front and the 10 micron filter after.
Jason
Old May 4, 2005 | 04:57 PM
Default Re: 255 fuel pump not cutting it. T4 car....options? (SFWD 1934)
well got everything finished up........and now of course i can't get any of my windbands to work. its always something.....
Old May 4, 2005 | 05:16 PM
1FSTHATCH's Avatar
I think the drain hole issue was seen on my car...and it works..we are near the 700 marker and are seeing plenty of fuel throughout cycle..As far as fuel shifting and needing to run a welded in sump..theres no need..run alittle extra gas in the car, and that extra tank weight will keep the pump from surging...Works great for me..save yourself the time and money..
Pickle
Old May 4, 2005 | 05:59 PM
Default Re: (1FSTHATCH)
yo whats up man yea it was your car i saw the drain plug thing on........i have the black coupe and we always seem to be pitted next to each other. i found a little bit more power in the car and ran out of pump. got a new one in there now so hopefully the car will go a little faster. anything new with your car?
Old May 4, 2005 | 09:11 PM
SpoolnG2's Avatar
Default Re: (Turbo-charged)
i've got mine sumped with an a1000 pump...if you want pics just pm me. I'll show u how i got mine all setup.
Old May 5, 2005 | 01:40 AM
1FSTHATCH's Avatar
lol, i thought that was you when i red that...I am actually in the middle of tuning my GM boost solenoid that allow but increase to the VSS on the car..We figured out that under 85 mph, the car can only handle 17psi before breaking loose..and after 86 mph we can increase to 25 or so without spinning...should be very interesting, i can wait to try it..
What the next event your attending??
Pickle
Old May 5, 2005 | 04:21 AM
haha that sounds crazy. i'll be at atco if the weather is nice. god seems to like to make every weekend rainy and cold lately. what happened to you guys at englishtown? just the weather?
Old May 5, 2005 | 01:12 PM
ReDHaTcHyGuy's Avatar
yeah pickle when is the next event ur going to .. i haven't seen u since i been working 3rd shift........ i may be down this weekend if ur at the shop , gotta drop off a stealth for howard to tune
Old May 6, 2005 | 12:41 PM
1FSTHATCH's Avatar
yea, the weather kept me from coming..I was tempted but it just didnt look promising..We put together some news things since vmp so i cant wait to get out to the next event..I hear nopi is outlawing spools now, which sucks, but i guess will have to be making changes...
Pickle
Old Mar 10, 2007 | 05:00 AM
DaveF's Avatar
what did you use ?
lostforawhile
Welding / Fabrication
19
Mar 12, 2011 10:18 AM
paulzy
Jul 26, 2005 09:59 PM
Green Lude 93
Jul 25, 2004 11:35 PM
1genmud
11
Mar 28, 2003 03:23 AM
