difference between b16 and GSR trans
i was jus wondering about the differences between the JDM '95 b16 n JDM '95 GSR trans, both w/ stock LSD. I know the GSR has slightly longer gears, any other differences?? Is there any reason y i shouldnt use a GSR tranny on a b16sirII??
thx
thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">cuz it will make it slower than it already is</TD></TR></TABLE>
You need shorter gears to make up for no torque.
i figured the GSR was stronger n i know the gearing is a little longer, but will that really make my car that much slower... according to the chart<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">http://www.ff-squad.com/tech/temp/Bgears.htm</TD></TR></TABLE>
it shouldnt be that much different
if its a y8 or a z6 then yea but dont believe me, go ahead and get the gsr tranny and regret it right after u put it in and think to yourself, damn i wish i would have listened to honda-tech
d16 is 127hp, the b16 is 170, the small difference in gear ratio will cause my b16 to feel like it has less than 130 hp, cause ur sayin<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">i have a z6 and ive beat an si and sol and both have b16s</TD></TR></TABLE>
so that si n sol both had gsr trannys??? n they both new how to drive??
d16-106 trq
b16-111 trq
the si had a itr tranny and the sol had a b16 tranny and they both know how to drive.
u dont have to listen to me im just telling u what i know. u can get the gsr tranny i really dont give a ****, its your car.
b16-111 trq
I have a gsr tranny on my b16 and there is a noticeable difference. It is in a ek coupe which is heavy. It is quite a bit slower especially the 1 to 2 shift and the 2 to 3 shift. It also takes a lot longer to accelerate if you are low in the powerband (4000) due to the lack of torque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si »</TD></TR><TR><TD CLASS="quote">I have a gsr tranny on my b16 and there is a noticeable difference. It is in a ek coupe which is heavy. It is quite a bit slower especially the 1 to 2 shift and the 2 to 3 shift. It also takes a lot longer to accelerate if you are low in the powerband (4000) due to the lack of torque. </TD></TR></TABLE>
most hondas have **** accel b4 4krpm, if i race some1 ill jus do it from a 50mph roll or somethin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NerveAgent »</TD></TR><TR><TD CLASS="quote">b16 with gsr tran
GSR with b16 trans
do that
</TD></TR></TABLE>GSR with b16 trans
do that
b16 trans
sportin the Ls with a b16 trans.....i beleive the guy that says he beat b16's with ITR trans..i keep up with my brother who has a ITR del sol...for early shifts..then he gets me in the middle of 3rd...and thats with VTAAAAAAAAK..
that same guy also said he beat a del sol w/ a b16 n a b16 trans n he got a d16z6, so ur sayin a z6 beat a b16 w/ itr trans???
the itr gears r even longer than a gsr correct??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoupeVtec2k »</TD></TR><TR><TD CLASS="quote">that same guy also said he beat a del sol w/ a b16 n a b16 trans n he got a d16z6, so ur sayin a z6 beat a b16 w/ itr trans???
the itr gears r even longer than a gsr correct??</TD></TR></TABLE>
No, the ITR gearing (for USDM) is identical to the B16 trans---the difference is the synchros and diff.
The JDM ITR gearing is the same for gears 1, 2 and 3---but the final drive is shorter, making it the best all motor tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bimmerman »</TD></TR><TR><TD CLASS="quote">I would go with the gsr trans if you are gonna boost it</TD></TR></TABLE>
well its already on the way... the diff is stronger, n i may boost eventually so i think ill have to eat the .2 - .4 sec i may loose, im sure ill beat a na d16 n it will still be decently quick, im not too worried
well its already on the way... the diff is stronger, n i may boost eventually so i think ill have to eat the .2 - .4 sec i may loose, im sure ill beat a na d16 n it will still be decently quick, im not too worried</TD></TR></TABLE>
Good choice. Alot of Honda people like to make alot out of nothing. You won't notice a difference and you will be getting a stronger trans, which is more important anyway. Besides, you can always upgrade your final drive to 4.785.
Jon
Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyWash1 »</TD></TR><TR><TD CLASS="quote">
Jon</TD></TR></TABLE>
smokerz212
19
May 6, 2006 06:10 PM
swaytec360
39
Jul 15, 2005 06:02 PM
