no check engine and no vtec plz help!!
Old May 3, 2005 | 08:36 PM
b16a_ef9's Avatar
Default no check engine and no vtec plz help!!
ive checked everything possible and i cant get the vtec to work. it works for a little bit after i reset it then it dosent work anymore after a few minutes. oil pressure is up and the oil pres. switch is good ,the solenoid works and the knock sensor is connected what else can it be !!!
Old May 3, 2005 | 08:41 PM
EL Vap133's Avatar
Default Re: no check engine and no vtec plz help!! (b16a_ef9)
Does your speedometer work? I am assuming by your name that you have a B16, right? Is it an OBD0 B16?
Old May 4, 2005 | 04:31 AM
greatwhiteshark's Avatar
Oil temperature up to the coeerct value? IIRC it's 60 deg C. Is the oil temp sensor working?
Old May 4, 2005 | 06:10 AM
Brownjd's Avatar
Default Re: (greatwhiteshark)
double check your oil level. if everything else is plugged in and working and speedometer like vap said then maybe an ecu issue? (i'm assuming vtec activation is up to the ecu)
Old May 4, 2005 | 01:58 PM
b16a_ef9's Avatar
Default Re: (Brownjd)
all my sensors work and my oil pressure is right so im gonna check the ecu
Old May 4, 2005 | 03:11 PM
Mach69's Avatar
Default Re: (b16a_ef9)
Just because there is no CEL doesn't mean the ecu isn't throwing codes. I don't have a CEL, but I know my ecu is throwing codes. I have codes 7 and 17 and until I floor it 100% or downshift, then only does the cel come on and I don't have vtec either. So what I am saying is check for codes regardless if you see a cel or not.
Old May 4, 2005 | 04:11 PM
b16a_ef9's Avatar
Default Re: (Mach69)
i dont have any codes either
the_dxB16
26
Sep 10, 2009 02:29 PM
JDMtegg19
10
Jul 10, 2009 10:08 AM
goldfinger93030
Jun 25, 2009 09:02 AM
crowder13
Mar 11, 2007 09:53 PM
zCivic
Dec 21, 2002 09:34 AM
